  2. Routes & Tracks
  3. Suggestion/Request - Exit without saving
routeplanner
13 Posts 5 Posters 4.1k Views 1 Watching
    @Carlo-Baronchelli said in Suggestion/Request - Exit without saving:
    I would really appreciate being able to choose whether to save the route I am editing or to exit without saving; or, in alternatively, I would like that, from the moment I open a path to modify it, a backup copy was created so that the original path can be recovered in case of serious 'messes' committed during the modification.
    I understand that suggestion.
    In that case I make a copy of a route before I edit it.
    Carlo Baronchelli Offline
    Carlo Baronchelli
    @Jack-van-Tilburg
    Yes, thank you. I also sometimes make this way.
    But it's not very comfortable...
    And sometimes I forget ...
    Drabslab 1 Reply Last reply
    • Carlo Baronchelli Carlo Baronchelli
      @Jack-van-Tilburg
      Drabslab Offline
      Drabslab Offline
      I am glad I am not alone πŸ™‚
      You may point to a shortcoming of the routeplanner here. All changes are immediately stored in the "official" version on the MRA server.
      It could perhaps be better that route editing is done on a temporary version (although still stored on the server) and that it requires an active intervention (save/save as button) of the user to put the changes also in the official version.
      Mopetenpit Jack van Tilburg 2 Replies Last reply
      • Drabslab Drabslab
        Mopetenpit Offline
        Mopetenpit Offline
        Mopetenpit
        @Drabslab
        110 % approval πŸ‘
        Carlo Baronchelli 1 Reply Last reply
        • Mopetenpit Mopetenpit
          @Drabslab
          110 % approval πŸ‘
          Carlo Baronchelli
          wrote on last edited by Carlo Baronchelli
          @Drabslab
          πŸ‘
          • Drabslab Drabslab
            Jack van Tilburg Offline
            Jack van Tilburg
            @Drabslab
            Whaha @Drabslab, 😁
            I do read in your posts that you were/are active in the IT world. And I think you sometimes use your experiences here on the forum to contribute to the help to fellow users.
            As an IT person you know that you are not allowed to work on an item until you have secured a (verified) backup? πŸ˜‡
              @Drabslab
              Whaha @Drabslab, 😁
              Drabslab Offline
              Drabslab Offline
              @Jack-van-Tilburg said in Suggestion/Request - Exit without saving:
              πŸ™‚
              Yes, I try to help a bit, possibly to the desperation of MRA folks when I start complaining about their percieved "hobby club" approach πŸ™‚ πŸ™‚ πŸ™‚
              However, I try to keep it fairly low key avoiding the IT slang, or references to development models and stuff like that.
              But you are a piece of the same cloth, ain't you Jack?
              • Drabslab Drabslab
                πŸ™‚
                Jack van Tilburg
                @Drabslab
                πŸ‘ 😊
                • Don Stauffer Offline
                  Don Stauffer
                  I've had similar thoughts, but I have finally developed the habit of 'copy, then edit'. After a bit it's become second nature.
                  • Jack van Tilburg Offline
                    Jack van Tilburg
                    There is of course another very big advantage in copying the route before you modify it.
                    If you are going to edit the copy, you can add the original route to the map via the <Routes> menu in the left column.
                    In this way you can keep the adjustments well in view and bring them back to original if necessary.
                      Drabslab Offline
                      Drabslab Offline
                      Very correct and this c(sh)ould be added to the temporary version way of working. You see the original version on screen + the modifications in "track changes lay-out" (another color for instance). And clicking the save button incorporates the changes in the original route.
                      • Drabslab Drabslab
                        Jack van Tilburg
                        @Drabslab said in Suggestion/Request - Exit without saving:
                        Nonsense. In doing so, you cannot go back to the original version. That will go wrong with many users!
                        Don Stauffer
                        Don Stauffer
                        Mopetenpit
                        Mopetenpit
                        Jack van Tilburg
                        Jack van Tilburg
                        Carlo Baronchelli
                        Carlo Baronchelli
                          16.0k
                          1.7k
                        • HERE maps updates
                          593
                        • MRA V5.2.1 (488) Kompass fest einstellbar auf β€žDynamische Kameraβ€œ
                          JΓΆrgen
                          JΓΆrgen
                        • Complimenten
                        • bundel purchase
                          1.1k
