  2. New Users' corner
  3. Hello from London
Hello from London
7 Posts 4 Posters 2.1k Views 1 Watching
  • Howard Gold Offline
    Howard Gold Offline
    Howard Gold
    Hi folks, nice to be here.
    I'm a new MRA user having always used paper maps for road trips before now. I use Google maps on my phone everyday to get from A to B but have never planned a longer trip this way before.
    We are heading to the Balkans in the summer and I've put most of it on the app but have some problems. Would this be the correct place to ask for help?
    I'll ask some questions here but if this is not the correct place then I'll try and move them. I very much appreciate you help.
    1. I'm getting a ferry from Ancona to Corfu and the app routes to another Italian port before crossing the water. How do I stop this? At the moment I have my trip set up as two trips, one to Ancona and the other from Igoumenitsa in Greece where the main trip will start.
    2. Is MRA compatible with Android Auto or will I just run a GPX file through the bikes satnav?
    3. What map to use for planning? I use Michelin paper maps because of the green shadowing but am used to Google maps look as I use it everyday.
    4. The route chosen in black obscures the road numbers and features, how do I see the detail and type of road?
    5. How can I mark what represents a 'day'? Some days have many waypoints, others none. I'd like to see what mileage is for each day, not just a cumulative.
    I have a specific problem with my route between Tujetsch and Andermatt. The route isn't taking me direct between my close waypoints, but when I compare with Tom Tom it shows the red route which is what I want. How do I force a change and get rid of the large detour?
    I really hope you'll be able to help as I'd like to get this route sorted and then try some simple local routes to figure out the uploading and the re-routing process.
    Thanks
    Howard
    Jack van Tilburg Nick Carthew Hans van de Ven MR.MRA 3 Replies Last reply
    • Howard Gold Howard Gold
      Thanks
      Howard
      Jack van Tilburg Offline
      Jack van Tilburg
      @howard-gold
      Welcome Howard.
      Have you looked around in the support section of the MRA Planner?
      Almost all the answers at your questions will be found in the support section:
      Support (click)
      Not that I don't want to help. But you can find much more information there that will be helpful for a starting user.
      Howard Gold 1 Reply Last reply
        Thanks
        Howard
        Nick Carthew Offline
        @howard-gold said in Hello from London:
        Welcome @Howard-Gold
        Two separate routes is probably the best solution but you could use the skip feature (looks like a 4x4 on the route point pop up). Use the skip function on the route point at the ferry port in Corfu. This effectively switches off routing and will draw a straight line.
        1. Is MRA compatible with Android Auto or will I just run a GPX file through the bikes satnav?
        At the moment, MRA Navigation is not compatible with Android Auto.
        1. What map to use for planning? I use Michelin paper maps because of the green shadowing but am used to Google maps look as I use it everyday.
        MRA Navigation uses the Here map so plan your routes on the Here map but you could use either Michelin or Google overlay maps for information whilst planning.
        1. The route chosen in black obscures the road numbers and features, how do I see the detail and type of road?
        In the toolkit, use Route line transparency to adjust the strength of colour for the line.
        1. How can I mark what represents a 'day'? Some days have many waypoints, others none. I'd like to see what mileage is for each day, not just a cumulative.
        Make separate routes for each day. You’ll find them easier to work on and they’ll load quicker.
        Make your route public and share it here would be the easiest way to solve the problem
        Use the Here map and turn off Seasonal Closures.
          @howard-gold
          Welcome Howard.
          Support (click)
          Howard Gold Offline
          Howard Gold Offline
          Howard Gold
          @jack-van-tilburg Thanks Jack. I've spent the afternoon learning how to use the app and have discovered quite a bit but have much more to learn.
            Howard Gold Offline
            Howard Gold Offline
            Howard Gold
            wrote on last edited by Howard Gold
            @nick-carthew said in Hello from London:
            Hi Nick,
            Thanks for your detailed help, some good tips there which have helped me greatly.
            I'm trying to understand shaping points and it seems they are the same as Via points, is this correct? I like the idea of having way points at the start and finish of each day with shaping points inbetween so I can see the day's mileage. I take your point though about each day being a route of its own.
            Think I'll make a local loop with many points to see how the satnav responds.
            Also, to email the route to myself and my girlfriend I had to make the route public. I was then concerned that my start point/ address was on it so made it private again. Any way around this?
            Thanks very much for your help.
            Howard
              Hi Nick,
              Howard
              Hi Nick,
              You’re welcome
              Shaping points (hand shape) are different from shaping points and must be visited. MRA Navigation can automatically skip one shaping point if it is missed. The app will re-route when you are closer to the next route point.
              Set your start and finish point away from your address.
                Thanks
                Howard
                @howard-gold
                Hello Howard, the road between Tujetsch and Andermatt is closed, see the black lines on the road. You can make the traffic layer visible via the maplayers
                If you use the season closures option, the route will go over this stretch, as @Nick indicated
                Jack van Tilburg
                Jack van Tilburg
                Howard Gold
                Howard Gold
                  258
                  siebo vd berg
                  siebo vd berg
                  509
                • Transport modes?
                • MRA 5.2.2 (489) Avoidances are not taken into account///Vermeidungen werden nicht berücksichtigt
                • No navigation instructions
                  Hans-Udo Erdmenger
                  Hans-Udo Erdmenger
                • Google maps and Streetview
                  Stevedo 6 0
                  Stevedo 6 0
