  2. Community Blog
  3. Loading Routes Garmin Zumo XT
Scheduled Pinned Locked Moved Community Blog
9 Posts 6 Posters 10.2k Views 3 Watching
  • MyRoute-app community
    Administrator
    Blog by Michel van Hagen
    In this blog post I tell you how you can easily and quickly load routes in your Garmin Zumo XT. Of course I use MRA Routeplanner Gold to create and export routes. From the route planner you can choose from 2 different files, namely gpx 1.1 and gpx 1.2. Both files are discussed in this blog with their own specific advantages and disadvantages.
    Read more
    Debra Lee 0 Massimo 1e Lynchy67 3 Replies Last reply
      Read more
      Debra Lee 0
      Debra Lee 0
      Debra Lee 0
      This post is deleted!
        Read more
        Massimo 1e
        Massimo 1e
        Massimo 1e
        @MyRoute-app-community hi! does it work the same way with Zumo XT2?
          Read more
          Lynchy67
          Lynchy67
          Lynchy67
          It is already possible to upload multiple routes using Garmin Express.
          • Massimo 1e Massimo 1e
            @Massimo-1e
            If you use the connector, yes. If you want to transfer the routes via the app, you also need the Tread app from Garmin.
            • Lynchy67 Lynchy67
              @Lynchy67
              No, you can select 10 routes and choose save as... (pop-up screen on the bottom). Then go to your download folder, upzip the file and select the 10 gpx files and copy/paste them in de GPX golder on your device
              nomko Lynchy67 2 Replies Last reply
                @Lynchy67
                Banned
                Have you tried the Garmin Drive app?
                Also, please read this:
                https://support.garmin.com/en-US/?faq=viCuQqsnlg2kOvcxESjqh7
                  @Lynchy67
                  Lynchy67
                  Lynchy67
                  Lynchy67
                  @Hans-van-de-Ven-MR-MRA
                  Yes I agree you can only select 10 at a time but once you them have all downloaded, using Garmin Express you can upload as many as you want in one go using Garmin Express.
                  Maybe the 10 Route limit should be addressed when the Route Planner gets an overhaul?
                  • Lynchy67 Lynchy67
                    @Lynchy67
                    It is on the list for major maintenance of the website, just like being able to export multiple routes in one go.
                    Please be patient.
                    Lynchy67
                    Lynchy67
                    Massimo 1e
                    Massimo 1e
                    Debra Lee 0
                    Debra Lee 0
                    • Log in
                      Rod Sydenham
                      Rod Sydenham
                      44
                    • Snelmenu / Quick menu
                    • AI pricing is too high
                      Emanuele 5
                      Emanuele 5
                    • Library Structure
                      John Matthews 0
                      John Matthews 0
                      Juudje39
                      Juudje39
