  3. Samsung Active tab 2
21 Posts 5 Posters 9.1k Views 1 Watching
  • Steve Lynch Steve Lynch
    Putting my Samsung S10 into Flight mode and MRA Navigation into Offline mode I cannot use any routes, so it seems Android also requires an internet connection to download a route into MRA Navigation.
    And yes I do have the maps downloaded on my Samsung.
    PAD 0
    PAD 0
    PAD 0
    @steve-lynch I think that’s the key thing to ensure is done - to have the regional map(s) you need for a trip or tour installed. These days, it’s relatively rare that neither a suitable phone signal nor a wifi hot spot can be accessed for the few moments required to open a route in Navigation. Not an infallible system, but I have managed just fine so far.
    I don’t know about the technicalities of it, but I wonder whether, at some point, it might be possible to introduce an option to install routes onto a device in a manner similar to installing offline maps? Then the need for internet ‘in the field’ could be largely negated. This could be a really helpful addition to the Route Planner / Navigation combination, particularly following a flat battery or device issue that meant navigation was interrupted en route.
    • PAD 0 PAD 0
      @con-hennekens Now there’s a thing… I haven’t found that to be the case. On both iPhone and iPad, if I am offline, I am unable to load any route, regardless of having used it previously. Could this be an iOS/Android disparity perhaps?
      @pad-0, that is strange. To illustrate that, I just opened two routes in my Navigation (did not even start routing). Then I closed the Navigatin App, put the device in flightmode and re-opened Navigation to find the two routes I viewed earlier can be opened without issues.
        Steve Lynch
        Steve Lynch
        Steve Lynch
        @con-hennekens
        Maybe you put Navigation in the Background rather than closing it?
        PAD 0 Con Hennekens 2 Replies Last reply
          @con-hennekens
          PAD 0
          PAD 0
          PAD 0
          @steve-lynch @Con-Hennekens Yes, I think it’s something along those lines. If the Navigation app is closed without exiting the route and flight mode is switched on, reopening the app sees the route still running. Likewise if wifi and cellular data are turned off. So maybe crossed wires over your meaning, Con? I thought you meant once a route had been opened, it remained accessible in Navigation for future use even when navigation had been exited.
          So at least that's halfway there. Unfortunately it does mean that if navigation is lost and no data signal or wifi is available, users are stuffed. It would be great to be able to install a route onto a device for use in Navigation though. In fact, it would be a great leap in terms of competing with dedicated sat navs which, of course, do very much that as a matter of course.
            @con-hennekens
            @steve-lynch said in Samsung Active tab 2:
            @pad-0 said in Samsung Active tab 2:
            No, definitely not! I just checked again, turning on flightmode first, and the routes are still usable. I also rebooted my P30 Pro in flightmode, and the routes I had been using before are still accessible, and routable. Except those to Bussang, like the ones in the picture above. That is because I do not have the map of France off-line anymore. The route loads and shows, but can't be calculated. Routes I do have the maps off-line for have no problem loading AND calculating without internet connection. There might be some kind of maximum period that routes are kept locally though, since routes I have been using months ago are not accessible anymore. They show up in the list, but are greyed out.
              Steve Lynch
              Steve Lynch
              Steve Lynch
              @con-hennekens
              Not sure what I did wrong above, probably the order that I did it was messed up.
              But on trying again you are correct, routes previously used are still available even with flight mode on.
              However after powering down my phone I can see the routes but I cannot navigate them.
              PAD 0 1 Reply Last reply
                @con-hennekens
                PAD 0
                PAD 0
                PAD 0
                @steve-lynch @Con-Hennekens Same here to a limited extent. The two routes I opened while testing all this recently are available, no others. It would seem there is a small cache. Something that seems strange is that if I open either of those two routes for navigation in offline mode, with no wifi or data on, and with no cellular signal available, if I exit them (via three dots icon and red ‘exit’ tile), I cannot re-open the routes for navigation. Nor can I do so by quitting the app and re opening it. That is as far as I went the other day.
                Yet I discovered just now that if I quit the Navigation app, then completely stop it from running in the background (i.e. double tap the iPad/iPhone home button, then swipe up on the app ‘tile’), then re-open it, re-open either route from the routes list and set it running for navigation, it works - all in offline mode. I can’t get my head around why, when doing less to disturb the whole process doesn’t??? It seems completely counter intuitive, but somehow it does!
                So another step in the right direction, but still hit and miss. And compared to being able to download routes onto a device and having it there with certainty, it still falls short.
                • PAD 0 PAD 0
                  That is strange indeed. I tried to do the same on my Android, but can't seem to find any "three dots menu" that allows me to quit Navigation the way is considered the right one. Therefore I ALWAYS quit Navigation by hard-stopping the program.
                  It works for me, but I agree that this is an omission, and could be improved and documented much better.
                    PAD 0
                    PAD 0
                    PAD 0
                    @con-hennekens Very odd that the Android version of the app seems not to have an exit button.
                    For reference, here’s how my iOS looks:
                    • PAD 0
                      PAD 0
                      PAD 0
                      Curiouser and curiouser!
                      • PAD 0 PAD 0
                        Yes, like @Matt-Flaming shows, the Android version DOES have a "3-dot menu" ONLY while navigating. If one presses the EXIT button there, it quits navigating, but not the entire program. It takes you back to the route overview from where you can start navigating the route again (the screen with the arrow).
                        • Con Hennekens
                          @matt-flaming said in Samsung Active tab 2:
                          But to exit out of the application, you just use the back button (or gesture if you are on a newer version of Android). You don't have to kill the app in recents menu.
                          Yes, but then the program stays active in the background, it does not close that way. The theory here was that after a program-exit the routes would not be usable without internet connection. Keeping it live in the background does not simulate that.
                            PAD 0
                            PAD 0
                            PAD 0
                            This is such a convoluted matter that it’s little wonder there is confusion!
                            In my view, it shouldn’t be necessary to be discussing it at all, given that providing the ability to load routes onto devices to enable offline mode fully would be a complete cure…
                            However… With both iPhone and iPad, in relation to @Con-Hennekens’ last post, what I have found is the opposite. I know it seems illogical (to put it mildly!) but, IN OFFLINE MODE, I am unable to return to a route UNLESS I DO CLOSE THE APP COMPLETELY BY STOPPING IT RUNNING IN THE BACKGROUND! If I don’t do this, I can’t return to navigation from the “route overview” screen - I just get endless buffering.
                            My brain hurts.
                            Steve Lynch
                            Steve Lynch
                            PAD 0
                            PAD 0
                            Eric Molimard
                            Eric Molimard
                              martin-phogel.de
                              martin-phogel.de
                              12.0k
                            • Issues on one-way streets when reversing routes
                              36
                            • Route line is not easy to follow on map
                            • F004 MRA Navigation Error
                            • Probleem met eigen Stay
                              Albert van den Elsen
                            • I need help with the track navigation settings
                            • POI functie 'strict'
