Android only update! (4.4.1)
@Marinus-van-Deudekom said in Android only update! (4.4.1):
I would certainly put shapingpoint 7 a bit more in the direction of 8
Exactly always ensure your waypoints are a good distance from a junction, intersection, roundabout or adjacent road. If you use the (expand) add waypoints option you have to check every single one.
I've also had MRA take me left onto a single track lane shortcut even though my friend's MRA was showing straight ahead which was the correct way.
I didn't have (show original route) turned on which would have helped but previously the white line (show original route) didn't follow the road correctly so I turned it off. Looks like it has been fixed now but I'll find out for sure on my trip on the 20th.
@JP-d said in Android only update! (4.4.1):
not sure if it is the same issue you are refering to but just so you know before your trip there is still an issue with the "original route" line not exactly "following the road" if you are navigating in offline mode
there are a couple of workarounds, details are here https://forum.myrouteapp.com/post/66551
