  4. Route cannot be created
17 Posts 6 Posters 208 Views 3 Watching
  • Robineke
    Robineke
    Robineke
    @Corjan-Meijerink Few days/week ago you have perfectly solved the problem for camper routes which indicated that point were not correctly positioned while car and motor were running fine.
    The problem stil remains for pedestrains. Can you solved that as well??
    • Robineke Robineke
      @Robineke There is no pedestrian navigation in MyRoute-app other than following the line for 'routes' you have created with the OSM map. You also do not receive voice instructions. Or am I missing something?
      Robineke 1 Reply Last reply
        Robineke
        Robineke
        Robineke
        @Rob-Verhoeff well I have the option to select "te voet". It also indicates a pedestrian person.
        I have 7 options to select.
        • Robineke Robineke
          @Robineke Di Sorry but Rob have the correct answer. There is no turn by turn guidance for pedestrians
            Robineke
            Robineke
            Robineke
            @Marinus-van-Deudekom I see what you write but please be aware I have used this for many years already and it was with voice instruction.
            If we visit an interested city we create a route for pedestrians and a line is made. So I do not understand what you mean it cannot. Have you tried before or is it what you experience now??
            • Robineke Robineke
              @Robineke Hi. This what's being told by the Devs. Maybe @Corjan-Meijerink van share his thoughts on this
                Robineke
                Robineke
                Robineke
                @Marinus-van-Deudekom Can you explain me what are: Devs??
                We had the same problem some weeks ago in Camper mode. Then it was solved by @Corjan-Meijerink . Unfortunately for pedestrains mode it remains an error.
                Corjan Meijerink Marinus van Deudekom 2 Replies Last reply
                • Robineke Robineke
                  @Robineke said in Route cannot be created:
                  Developers, thus including me 😉
                  Sorry, I have absolutely no clue what you are talking about.
                  There was an issue for campers which was fixed.
                  But we never supported pedestrian navigation in this app.
                  • Robineke Robineke
                    @Robineke, to add to Corjan's reply:
                    Not with turn-by-turn instructions anyway.
                    Yes you can select "by foot" indeed, but then you get a follow-the-line navigation on the OSM map, without voice instructions. I have walked using the app a lot, and it works just fine, but not in the "Navigation Next" module with the HERE map, and without instructions.
                    • Bouke Ent
                      Bouke Ent
                      Bouke Ent
                      for walking i use komoot. route can i make in webplanner with osm maps and export to komoot.
                      • Robineke Robineke
                        @Robineke Devs is developers, the tech brain behind the app😁
                          Robineke
                          Robineke
                          Robineke
                          @Corjan-Meijerink strenge since I have used it many times.
                          It is a pitty to learn walging is not alle by MRA, it was so helpfunctie.
                          • Robineke Robineke
                            @Robineke, walking with the app is still possible. Plan your route on OSM, choose "by foot". You cannot tap "Navigate" in the app, but you can open the route and press the compass. It will follow you and you can follow the line. Who needs instructions when walking?
                              Robineke
                              Robineke
                              Robineke
                              wrote on last edited by Robineke
                              #14
                              @Con-Hennekens Instructions are very usefull, but that is personal. I am stil surprised the possibility is gone.
                              And moreover why have this way of navigation to select if it does not work.
                              • Robineke Robineke
                                @Robineke That's a fundamental difference between planning and navigation 😉
                                You can still plan hiking routes but our app just doesn't offer to navigate them as we believe that quality is suboptimal (read: terrible).
                                • Robineke Robineke
                                  @Robineke, What was never there cannot be gone ;-). As mentioned before, the transport method "by foot" is still very useful for Follow-the-line routing, and for planning like Corjan said.
                                    Robineke
                                    Robineke
                                    Robineke
                                    @Con-Hennekens No need to believe me 🙂
                                    Bouke Ent
                                    Bouke Ent
                                    Robineke
                                    Robineke
                                      Alderweireld Rudi 0
                                      Alderweireld Rudi 0
                                    • Map movement
