  4. TomTom to Nav6
TomTom to Nav6
2 Posts 2 Posters 611 Views 1 Watching
  • Stormforce8
    Stormforce8
    Stormforce8
    Hi I'm in need of some help!
    I have some files that I want to upload to my BMW nav6. They were created on a TomTom my drive app. I've managed to extract the gpx file but when I upload this to MyRoute app the whole route changes, the only way I've found to keep the route the same is to upload it as a Route track. however, I then cant seem to get it to upload to my Nav6.
    I'm doing the same thing I've always done. The app says its downloaded, but when I switch the Nav6 on there is no route to import.
    Any advice would be appreciated.
    many thanks in advance
    Gerard Wullink 1 Reply Last reply
    • Stormforce8 Stormforce8
      Gerard Wullink
      Gerard Wullink
      Gerard Wullink
      wrote on last edited by Gerard Wullink
      @Stormforce8 Bare in mind that you change the map from TomTom to HERE and you change the route calculation, again from TT to Garmin. Its not strange the resulting routes differ. Also the settings in de navigation devices can differ; avoid ..., fastest versus adventurous etc etc.
      What you should do is import the gpx from TT into MRA on a HERE card (which is used bij Garmin/Navigator). This wil give a different route. Now add the gpx file as a layer behind the route. Add via points until the routes are the same. Now export to your Navigator. Have fun!
      Gerard Wullink
      Gerard Wullink
      Stormforce8
      Stormforce8
        Jack 13
        Jack 13
        473
      • Myrouteappstay
      • Route uploaden
        Johan 5q
        Johan 5q
      • Track colors by section.
        Rolf Engelsman
        Rolf Engelsman
        Marcel Versluis
        Marcel Versluis
