  4. MRA Routes to Goldwing Nav
3 Posts 3 Posters 1.5k Views 1 Watching
  • Mark Hutchins 0
    Mark Hutchins 0
    Mark Hutchins 0
    Uploading a .gpx route exported from MRA Route Planner into the 2018+ Honda Goldwing Nav has failed me every time. I tried various gpx formats, combinations of routes, waypoints and tracks options, but all it brings over is the start point and little else.
    The only workaround is the REVER export option specifically to the Goldwing, so I save my route as a gpx, open it in REVER, Export GPX, and select Honda 2019 (99 Waypoints). This brings up the full route in the Goldwing's Nav.
    Has anyone found a way to get MRA routes to upload to the Goldwing Nav without having to do go to another app?
    Tom Cat 1 Reply Last reply
    • Mark Hutchins 0 Mark Hutchins 0
      Tom Cat
      Tom Cat
      Tom Cat
      @Mark-Hutchins-0 Take a look at this video. It shows you how to set up a route to work with the Honda Nav. I believe the system you use to create your maps doesn't matter as long as it has the right features.
      https://youtu.be/cjPrvaP7IJ0?si=HSE_hPrOLqmwOTJ6
        The Goldings Nav isn't the best. But the GPX files from MRA should work. I've tried it once or twice in the past and it did work.
        Tom Cat
        Tom Cat
        Mark Hutchins 0
        Mark Hutchins 0
          Andy Nicholson
          Andy Nicholson
          Jack 13
          Jack 13
        • Event attendees
          cerfskysky.com
          cerfskysky.com
        • Live connection with EV
        • Route uploaden
          Johan 5q
          Johan 5q
        • Track colors by section.
