  3. rename POPUP?
rename POPUP?
4 Posts 2 Posters 804 Views 2 Watching
  • Aiello antonino
    Aiello antonino
    Aiello antonino
    The following operation seems to have changed for a few days. Previously, if you moved a Waypoint, the popup with the new description appeared, you could decide to rename it, or leave the proposed description. Now, however, the Waypoint is moved but the popup window is no longer shown, where you could decide whether to rename it or leave everything as proposed, among other things, if you pressed the CANCEL button in the popup, it remained with the name it had originally, in my opinion very comfortable... is this an intentional change? In my opinion more uncomfortable…
      @Aiello-antonino Check whether you've unintentionally disabled this setting in the toolkit menu:
      The setting freely translates to: Ask for waypoint name...
      Aiello antonino 1 Reply Last reply
        Aiello antonino
        Aiello antonino
        Aiello antonino
        @Stefan-Hummelink ooooo…perfect thank you! I didn't realize I had removed that option...🤦‍♂️
          @Aiello-antonino You're welcome 😉 !
          Aiello antonino
          Aiello antonino
          • Custom POI color and icons
          • F004 MRA Navigation Error
            12.2k
          • File / Creation date
            Robineke
            Robineke
            291
