  4. Via point: display of scheduled stop time
7 Posts 4 Posters 1.6k Views 2 Watching
  • Corrado Miniati
    Hi everyone,
    at the top/right corner the icon of the via point chosen with the Route planner is displayed both for the type (WC, fuel, hotel....) and the relative colour.
    Could you also view the scheduled stop time insert in the route planner without having to go and check it via web?
    Thanks a lot
    Corjan Meijerink RetiredWingMan 2 Replies Last reply
    • Corrado Miniati Corrado Miniati
      Hi everyone,
      Thanks a lot
      @Corrado-Miniati-0 Thanks for sharing!
      Indeed something we would like to add 🙂 It's on our list.
      Corrado Miniati 1 Reply Last reply
        Hi Corjan, great news, thanks for the reply.
        Do you already have scheduled times?
          @Corrado-Miniati-0,
          It could also be added to the information box that appears if you tap a waypoint icon that contains a picture or a note (and in that case a pause time).
            @Corrado-Miniati-0,
            Hi Con, yes too, great advice, in the meantime you can do it like this.
            Applying it directly on the icon is immediately visible without any additional operations, the Corjan update will be welcome.
              Hi everyone,
              Thanks a lot
              @Corrado-Miniati-0 that information is already displayed at the bottom of the screen. You can cycle between next waypoint, next viapoint or final destination.
                @RetiredWingMan, @Corrado-Miniati-0 his suggestion is to have the planned pause time visible (if any), not the time of arrival there. That is indeed visible at the bottom if you cycle to the right option.
                  Jack 13
                  Jack 13
                  468
                • Myrouteappstay
                • Track colors by section.
                  Rolf Engelsman
                  Rolf Engelsman
                  Marcel Versluis
                  Marcel Versluis
                • Customize dashboard on smartphone
