  4. Truck route calculation differences between Web and Next! App
5 Posts 3 Posters 1.6k Views 3 Watching
  • Kai Schmitz
    Kai Schmitz
    Kai Schmitz
    I work as a truck driving instructor in Germany. I use MRA to plan my training routes and unfortunately there are actually some serious problems with how the routes for trucks are calculated in the web version.
    Whenever I set the route type (web version) to truck, unnecessary detours are calculated:
    The Next! App is calculating the same route fine.
    Even if I set the web version to the vehicle type "Motorhome", everything is fine.
    And before you ask: Yes, the route can be traveled with a truck including a trailer. I recorded the route in advance with a GPX logger. The calculating error inside of the web version always occurs when the vehicle type is set to “truck”, regardless of whether a trailer is specified in the vehicle data or not.
    This is not at all useful or reliable. I strongly request that this issue will be resolved soon!
    HABVEN aka MrMRA Corjan Meijerink 2 Replies Last reply
    • Kai Schmitz Kai Schmitz
      @Kai-Schmitz
      Can you share the url from the route? Make sure it is set to public
      Kai Schmitz 1 Reply Last reply
        @Kai-Schmitz
        Kai Schmitz
        Kai Schmitz
        Kai Schmitz
        wrote on last edited by Kai Schmitz
        https://www.myrouteapp.com/route/open/8510674
        https://www.myrouteapp.com/track/open/536477
          @Kai-Schmitz The issue has been fixed! 🙂
          Behavior in app and web should be identical now.
          I see that the route you shared has been deleted unfortunately but I am quite confident that everything should work as expected.
          Thanks for sharing 😃
            Kai Schmitz
            Kai Schmitz
            Kai Schmitz
            @Corjan-Meijerink many thank's for the Fix!
            Kai Schmitz
            Kai Schmitz
              153
              Ruud Bijkerk
              Ruud Bijkerk
            • Route exporteren uit beta
              Johan 5q
              Johan 5q
              126
            • iPad - zooming out
              Big Al 1
              Big Al 1
