  2. Routes & Tracks
  3. Zumo 395 recalculate mode
3 Posts 2 Posters 1.2k Views 1 Watching
  • Maurizio f
    Maurizio f
    Maurizio f
    Hi, do you know how is possible to switch off the recalculation mode on the Garmin Zumo 395.
    When I import a travel the system recalculate the route in different mode. Thank you very much
    • Maurizio f Maurizio f
      @Maurizio-f
      Click on the key (Tools) in the start screen
       Then click on menu “Navigation”
       Then click on "Recalculation Mode"
       Select “Off” and click “OK”
      • HABVEN aka MrMRA
        And
        Do not start the route until you have a full fix (= at least 3 green dashes), so only when the Zumo has found enough satellites and is ready for navigation.
        Maurizio f
        Maurizio f
          459
        • Myrouteappstay
        • Track colors by section.
          Rolf Engelsman
          Rolf Engelsman
          Marcel Versluis
          Marcel Versluis
