  3. Route from MRA to Garmin zumo 350
zumo 350basecamppoiconnectorgpx versions
2 Posts 2 Posters 1.1k Views
  • infoevertkuiken.nl
    infoevertkuiken.nl
    infoevertkuiken.nl
    To start off: I use MRA to create routes with shaping and via POI and want to drive those routes with those waypoints in them. So no use telling me to convert the track to a route in the Garmin...
    I tried I think all possible ways to get a route from MRA into my Garmin and ended up with either all waypoints "hard"(flags) or only start and end waypoints (and other "hard" via POI) in them.
    What I want is the route with soft (forming) POI and hard (via) POI in my Garmin zumo 350. I tried the Connector, tried saving GPX in version 1.0, 1.1 and 1.2. Not one seems to give me what I want. So I keep using BaseCamp to get the routes from MRA in to my Garmin.
    There must be a way to get what I want without using BaseCamp?
    • infoevertkuiken.nl infoevertkuiken.nl
      @Evert-Kuiken said in Route from MRA to Garmin zumo 350:
      So it's no use telling you what you can do best. 🙂
      Unfortunately, exporting and use of MRA routes works best with the Garmin XT. With other types the miner works well and it is recommended to use a track.
      infoevertkuiken.nl
      infoevertkuiken.nl
      • Route wordt afgesneden
        Wim Hompes
        Wim Hompes
        Jacob Waterweg
        Jacob Waterweg
      • OSM Routing with MRA
      • Knop rondrit
