  2. Routes & Tracks
  3. Export from PC to BMW NAV. V failed
4 Posts 4 Posters 1.1k Views 2 Watching
  • Michael Scheuer
    Michael Scheuer
    Michael Scheuer
    Hello since today I got a problem. After export of a rout with different waypoints my GPS (BMW NAV. 5) received only start and target. In Trip information it shows the roaute as planned.
    What did I wrong? In the past it worked fine for years.
    May I ask for your support, please? Thanks in advance.
    HABVEN aka MrMRA Håkan Pettersson 0 2 Replies Last reply
    • Michael Scheuer Michael Scheuer
      @michael-scheuer
      Did you use the BMW export?
      • Spili
        Spili
        Spili
        When you export it from PC to nav you have to in Nav convert route to track.
        And then is works ok.
          Håkan Pettersson 0
          Håkan Pettersson 0
          Håkan Pettersson 0
          @michael-scheuer
          Solution:
          This is a gpx format error. BMW Navigator VI dont work properly with gpx 1.2, MyRouteApp need to change to or add another line in export tool for gpx 1.1 (route/track/POI)
          So you need to use "save as..." and choose .gpx 1.1 (route/track/POI) option and aftwerwards copy the created gpx file from your computer over to the navigators GPX folder and then in navigator import and change soft waypoints to hard waypoints. Voila.
          Spili
          Spili
          Håkan Pettersson 0
          Håkan Pettersson 0
          Michael Scheuer
          Michael Scheuer
          • In het kort......
          • Route probleem
