  2. Routes & Tracks
  3. Route dot/hand 6 error
3 Posts 2 Posters 1.1k Views 1 Watching
  • Erik Vullings
    Erik Vullings
    Erik Vullings
    In several routes made in MRA the routepoint no.6 is giving troubles. If 6 is the endpoint, it is not seen; so 5 is the endpoint. If it is on a route there is a straight line between 5 and 6. To avoid this I place 6 just behind 5. First I thought it was the Zumo criting the fault, but with the GPX viewer app I see the fault already on the PC when saving the GPX.
    This error is quite new, did not have it before (till a month ago or so).
    • Erik Vullings Erik Vullings
      @Erik-Vullings
      Hi Erik,
      The issue has already been reported to the development team and they are investigating it.
      Thanks for passing on.
      Erik Vullings 1 Reply Last reply
        @Erik-Vullings
        Hi Erik,
        Erik Vullings
        Erik Vullings
        Erik Vullings
        @Hans-van-de-Ven-MRA-Master Dank je. (kwam er inmiddels achter dat het niet is met HERE kaarten om het nog ingewikkelder te maken)
        Erik Vullings
        Erik Vullings
        • In het kort......
        • Route probleem
