  4. RouteLab Default Location
4 Posts 3 Posters 1.2k Views 3 Watching
  • Tom.Fox
    Tom.Fox
    Tom.Fox
    Is there any reason the default map in Route Lab doesn't go to somewhere near my location? I'd even accept a few hundred miles away, but not several thousand. I have enabled location in Firefox. If I remove that permission, it prompts for it and grant it. It still defaults to Europe.
    Is this normal behavior?
    • Tom.Fox Tom.Fox
      @TobFrommepm.me A map in the browser on your computer often shows an incorrect location because desktops lack GPS and rely on IP address, WiFi networks, and browser settings, which can be affected by VPN or caching.
        Same problem for me! The most simple solution is to make your home a favourite.
        • Tom.Fox
          Tom.Fox
          Tom.Fox
          Oh great, my username changed with the SSO issue. I'll look into that one.
          @Rob-Verhoeff I understand those things, but other web sites work fine, just not MRA. It even requests location sharing, but fails to grab it.
          I'll look into @white.mouse's suggestion. Any way to have it start at a favorite?
          Tom.Fox
          Tom.Fox
          • Custom POI color and icons
            36
            b0hd1
            b0hd1
            12.2k
          • F004 MRA Navigation Error
          • Probleem met eigen Stay
            Albert van den Elsen
