Carpe Iter Caretta
I recently bought the C4, if I like it I will order the Caretta
This is also a nice device: https://www.dmdnavigation.com/news/6967716521efccdb00059e93/
@Hans-van-de-Ven-MR.MRA said in Carpe Iter Caretta:
For sure - however, as mentioned, the Nor7e only has a screw connection on the back as a power supply. That's too inconvenient for me.
I too was looking at the Caretta, as it's cheaper than DMD, and I don't need all the DMD software. Hey, I have MRA
I quickly dropped the idea. Note how big the cradle is, 3,6 cm wider than the device. Maybe not an issue for others, but a deal braker for me.From their web site:
Caretta Device: ~194x129x33mm (LxWxH).
Holder (Approx): 203x165x56mm (LxWxH), -
Holder (Approx): 203x165x56mm (LxWxH),@Makro said in Carpe Iter Caretta:
Yeah - that's something to consider, and the same goes for the weight.
The CI Pads have always been bulkier and heavier than the Thork / DMD devices. My CI V4B had the same outer dimensions as my T865, with an inch less in display size. But honestly, I love the massive, bombproof design of CI's devices and holders!
I intend to replace the T865 with the Caretta, and as the Honda has a rock-solid mounting point and plenty of space above the dashboard, I don't care about size or weight.
What's coming up to replace the T665 on my Triumph is still to be discovered. The Evotech mount can't handle a ~1kg device without too much vibration, I guess. So I may go for a smartphone solution, even though I swore never to use a smartphone as a nav device again...
@Martin-Wilcke said in Carpe Iter Caretta:
I have been using rugged phones for years now, and I do not consider them phones...
Phone is in my pocket, navigation device (which happens to be called a phone) on my handlebar... -
Phone is in my pocket, navigation device (which happens to be called a phone) on my handlebar...@Con-Hennekens
I'm calling a phone a "navigation device" only if it was designed and built explicitly for this purpose - and there are just a few. There are some key differences, which set them apart from other devices, where THIS is probably the most important one (taken from Caretta specs, but Thork devices have the same feature):
There are many users out there who have been using different phone/tablet types for navigation for years without encountering any overheating problems, or at least getting used to dealing with them. That's absolutely fine, and I don't want to start a debate on this.
I can only tell from my own experiences. I used several phones for navigation, from an iPhone and a Samsung to a Blackview. They ALL struggled with overheating at some point. That's why I switched to Thork devices.
However, things change over time, and maybe there are some "regular" phones available now that will work flawlessly even in real hot conditions with a blistering sun all day and a temperature close to 40 °C ( which can easily happen when riding in Southeast Europe) while always on with maximum display brightness and permanently charged. But honestly, I doubt it.
@Martin-Wilcke, you will not hear me say that a "normal" phone is equally specced as a Thork phone of course. But for me my Thinkphone is certainly sufficiently specced. I ride a naked, so the phone gets some airflow, that helps. And with temperatures of 40 degrees Celsius, you will likely find me at some terrace instead of on my bike...
If I would be so adventurous as to go riding in let's say Morocco, I would definitely add some demands to my navigation device's specs too. -
If I would be so adventurous as to go riding in let's say Morocco, I would definitely add some demands to my navigation device's specs too.@Con-Hennekens said in Carpe Iter Caretta:
Yep, as always: different horses for different courses.
You don't need to go to Morocco to have 40°C - this was in France in May 2023:
Hi all, Richard from Carpe Iter here – late to this thread, but a few facts that came up:
Every Caretta kit includes a one-year premium subscription for MyRoute-app.
Weight: Caretta 630 g, cradle 390 g. On paper that looks heavier than some alternatives, but on a motorcycle a few hundred grams make no real difference – what matters is how the device is held, and that's where we put the effort: the cradle has a free-float damping system that isolates the Caretta from engine vibration.
The kit comes with an AMPS base, so it goes on standard AMPS mounts. We haven't tested it on the Evotech mount specifically, so we can't promise anything there, but we haven't seen mounting or vibration issues on the bikes it's been fitted to.
@MartinW – you've had yours for a while now: how is it working out on the Honda, and did you try it on the Tiger?
