Move a GPS point on the map
Hi,
When searching for a location on the map using GPS coordinates, the result is often not 100% accurate.
The corresponding yellow marker cannot be moved, but it would be very useful to be able to drag it and place it at the exact location after verifying the correct position on the map, and then convert it into a waypoint.Thanks
Hi,
@Corrado-Miniati
The yellow marker represents the exact center point of the coordinates you provided. The surface area covered by your coordinates may vary, as different types of coordinate systems have different levels of precision.
The yellow marker appears at that location, but it is not yet a waypoint. Did a screen appear asking if you wanted to set that location as a waypoint on the map? If you accepted that, you will see the familiar blue marker, which you can then move around as you please. -
@Corrado-Miniati
The yellow marker appears at that location, but it is not yet a waypoint. Did a screen appear asking if you wanted to set that location as a waypoint on the map? If you accepted that, you will see the familiar blue marker, which you can then move around as you please.@TorqueRider
Thanks for the feedback.
Yes, I did that, but what I was asking for is simpler with fewer steps: first move the yellow icon and then convert it into a via waypoint.
