personal heat map discrepancy/ editing
not sure if its me not using the heat map correctly but it only shows a handful of routes i have actually ridden.
is there a way of going through my personal library and adding them to the heat map?thank you tom
I feel similar: looks like the heat map is too aggressive. At areas I often ride, it's completely painted red. I can't detect single rides, or differentiate if the ride was at parallel roads. While single or seldom rides at other areas are painted in light blue or just not painted; looks like I did never ride in this area.
Sometimes, I want to switch off the heat map and switch on standard view with thin lines for each tracklog of selected folder/root
I’ll check what I can improve!
