  2. MRA Routeplanner Next Beta
  4. F033 Motorcycle - tank range ?
2 Posts 2 Posters 24 Views 2 Watching
  • Hubert Thoring
    Where can I adjust the range because 70km is not correct, it is easily 300km per tank filling see picture 1
    I found it after a long search. Who set the standard at 70km, is not really meant that way?!
    Note: in routing settings can be found below
    • Leave blank to use your general range of 70 km.
    I have now set it to 300km for my motorcycle ..
    iPad 9. G iOS 27.2.1/iPhone 16e iOS 27.2.1/ iPhone Xr iOS 18.7.11 / PC Win11 /❗️MRA & BMW Cradel & Remotek One ❗️.. & ..❗️Navi Halter3D Druck Senkrecht ❗️
      wrote last edited by
      The 70 km isn't a value we set for everyone: without a range the planner gives no fuel warning at all. It's the general range stored on your account, which is used for any vehicle that has no range of its own. It was most likely typed into the "Tank range" field in the planner's Routing settings at some point. Now that you have set 300 km on your R1250GS, the warning uses that for the bike. You can also set it under Profile > Garage when you edit the bike. If you'd like to fix the general range too: remove the vehicle from the route, and the same field in Routing settings changes the general range. Leave it empty if you don't want fuel warnings without a vehicle.
      • Corjan Meijerink Corjan Meijerink locked this topic
      • Online map settings
        398
        Jack 13
        Jack 13
      • Navigatie met DMD tablet
        Arjan de Vries
        Arjan de Vries
      • No skip waypoint on an A to B route
      • Myrouteappstay
        Bé Jeuring
        Bé Jeuring
      • Map met routes Offlne zetten lijkt het niet te doen
        Marcel Versluis
        Marcel Versluis
