<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[F033 Motorcycle - tank range ?]]></title><description><![CDATA[<p dir="auto">Where can I adjust the range because 70km is not correct, it is easily 300km per tank filling see picture 1</p>
<p dir="auto"><img src="/assets/uploads/files/1794815019536-img_2997.jpeg" alt="IMG_2997.jpeg" class=" img-fluid img-markdown" width="1170" height="650" /></p>
<p dir="auto">I found it after a long search. Who set the standard at 70km, is not really meant that way?!</p>
<p dir="auto">Note: in routing settings can be found below</p>
<ul>
<li>Leave blank to use your general range of 70 km.</li>
</ul>
<p dir="auto">I have now set it to 300km for my motorcycle ..</p>
<p dir="auto"><img src="/assets/uploads/files/1794815435472-img_2998.png" alt="IMG_2998.png" class=" img-fluid img-markdown" width="1170" height="2532" /></p>
]]></description><link>https://forum.myrouteapp.com/topic/12773/f033-motorcycle-tank-range</link><generator>RSS for Node</generator><lastBuildDate>Mon, 16 Nov 2026 12:58:44 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12773.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 Nov 2026 07:49:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to F033 Motorcycle - tank range ? on Mon, 16 Nov 2026 08:54:00 GMT]]></title><description><![CDATA[<p dir="auto">The 70 km isn't a value we set for everyone: without a range the planner gives no fuel warning at all. It's the general range stored on your account, which is used for any vehicle that has no range of its own. It was most likely typed into the "Tank range" field in the planner's Routing settings at some point. Now that you have set 300 km on your R1250GS, the warning uses that for the bike. You can also set it under Profile &gt; Garage when you edit the bike. If you'd like to fix the general range too: remove the vehicle from the route, and the same field in Routing settings changes the general range. Leave it empty if you don't want fuel warnings without a vehicle.</p>
]]></description><link>https://forum.myrouteapp.com/post/89561</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/89561</guid><dc:creator><![CDATA[Corjan Meijerink]]></dc:creator><pubDate>Mon, 16 Nov 2026 08:54:00 GMT</pubDate></item></channel></rss>
