  2. MRA Routeplanner Next Beta
  4. Add Selection Mode to the POI Menu
3 Posts 2 Posters 12 Views 2 Watching
  • Corrado Miniati
    wrote last edited by
    Hi,
    Would it be possible to add the same Single Selection and Multiple Selection modes currently available in the Waypoints menu to the POI menu as well?
    This would make POI management more consistent with waypoint management and could simplify route planning, especially when adding, modifying, or removing multiple POIs during the planning process.
    Having the same selection options in both menus would provide a more intuitive and uniform user experience throughout the Planner.
    Thank you.
      Thanks for the suggestion, it makes a lot of sense. The POI list in the planner now has the same Select mode as the waypoints. You can tick POIs one by one, use Select all, Shift-click to select a run or Ctrl-click (⌘ on a Mac) to pick single ones, and then remove them all at once. One undo brings them back if you change your mind. If you have filtered the list by type, Select all only takes the POIs you see.
      It will be on the beta with the next update.
      • Corrado Miniati
        Great, thanks
        • Corjan Meijerink Corjan Meijerink locked this topic
          guenniguenzelsen
          guenniguenzelsen
          721
        • Na rit vanuit event geen tracklog
          Hanza 0
          Hanza 0
        • Storage of tracklogs
          Rob Veerman
          Rob Veerman
        • Route calculation between newly added POIs on the map
        • Trajectcontrole: visuele kleurindicatie gemiddelde snelheid
        • Hoe vanuit CarPlay tijdens een clubrit bericht sturen?
        • Trips in Commercial Clubs?
          Hanza 0
          Hanza 0
