  2. MRA Routeplanner Next Beta
  4. Has OpenCycleMap been forgotten?
7 Posts 3 Posters 72 Views 2 Watching
  • Corrado Miniati
    wrote last edited by Corrado Miniati
    Hi Corjan,
    just a quick clarification: you mentioned OpenCycleMap, but I don’t see it among the layers, was it left out by mistake?
    Thanks a lot
      Set travelmode to cycle πŸ™‚
      Corrado Miniati 1 Reply Last reply
        Okay, I’ve found it.
        Personally, I also use it to check roads because it has a well-designed layout; would it be possible to keep the layer visible for other motor vehicles as well?
        Thanks a lot
        • Frans v Dijk
          Frans v Dijk
          Frans v Dijk
          Waar vind ik dat ? Stel de reismodus in op cyclus
          • Frans v Dijk Frans v Dijk
            @Frans-v-Dijk
            Yes, correct
              Hi Corrado, it wasn't forgotten: OpenCycleMap was only listed when the route's travel mode was set to Bike, as Frans found. That was easy to miss, so we've changed it. With the next update it will always be in the map style list under More map layers, whatever your travel mode. If you choose it on a cycling route, it comes back by itself on your cycling routes. If you choose it on another route, it stays on until you reload the page.
              • Corrado Miniati
                Great news, thanks Corjan
                Frans v Dijk
                Frans v Dijk
                • Online map settings
                  975
                • MRA-pictogram
                  BMcG
                  BMcG
