Google Street view windows
Hi,
Is it possible to make the street view window bigger than the map view?
So that both are visible, on top the street view, and half of that (or smaller) is the map view.
I was thinking maybe take it even further, and optionally open the streetview in its own window!
Ideal for dual monitor setups! -
I’d be happy enough if it went back to how it was in the previous version. In full-screen mode, with a box at the bottom showing the map and your position, so you know which way you’re facing!
Ik zou al tevreden zijn als het weer wordt zoals in de vorige versie. In het volledige scherm met onderin een kader met de kaart en de positie zodat je ook weet welke kant je op kijkt!
There is a fullscreen mode, but without a smaler map.
Corjan Meijerink locked this topic
