  2. MRA Routeplanner Next Beta
  4. Route-plan PDF: detailed map working, but some long directions are clipped
5 Posts 2 Posters 34 Views 2 Watching
  • Gordon Hodges
    Gordon Hodges
    Gordon Hodges
    wrote last edited by
    I have been testing the route-plan PDF in Safari on 20 October using a disposable test route.
    It was good to see the detailed street map render successfully this time. My earlier export had produced an outline instead, so this is a useful improvement for reviewing the route.
    The new PDF also retained the waypoint notes, icons and planned stop allowance.
    One remaining issue appeared in the directions: some long destination strings, particularly names separated by slashes, extend beyond the right-hand column and are cut off. Ordinary instructions generally wrap correctly.
    Could these longer destination strings be wrapped within the column, including where there are no spaces between the destinations?
    I have retained the example PDF and an image of the affected page if useful.
      Yes, please share screenshots of the issue and a link to the route you used to create it. That's all I need 🙂
        Nevermind, fixed it. Will be available somewhere today.
        • Gordon Hodges
          Gordon Hodges
          Gordon Hodges
          Thanks Corjan. I have retested the PDF in Safari on 22 October using the same disposable route. Both previously clipped instructions now wrap fully within the column and are readable. The detailed map is also rendering correctly. A useful improvement—thank you.
            Most welcome
            Gordon Hodges
            Gordon Hodges
            • Online map settings
              972
            • MRA-pictogram
              BMcG
              BMcG
              194
