  4. What is this? (Basic account)
5 Posts 3 Posters 57 Views 2 Watching
  • Jörgenundefined Offline
    wrote last edited by
    Hi,
    I just tested something with a basic account (for a friend) and had just three waypoints and a very strange route between these three waypoints. (on OSm Map)
    I can´t get a route between WP 2 and 3, even if I add a new WP.
    The route always goes via Cologne.
    I just checked this with my normal account, and I got the same result. Very strange?
    Brian McGundefined John S Parryundefined 2 Replies Last reply
    • Jörgenundefined Jörgen
      Hi,
      Brian McGundefined Away
      @Jörgen I think in the "Toolkit" you have the avoidance option "Highways" enabled
      A similar route works correctly for me in a basic account with "Highways" disabled
        Hi,
        John S Parryundefined Offline
        I've found that disabling all avoidances in Toolkit makes your life easier. Coincidently, I ran into this last night:
        I couldn't figure out why I couldn't continue a straight-line route path between WP4 and WP5 on Highway 261. It seemed simple enough. In interrogation, I saw that I didn't have "Disable seasonable closures" checked:
        Checking "Disable seasonable closures" yielded the correct intent:
        Irony alert -- The seasonal closure refers to winter. In the Southwestern US, we're in the middle of summer. A hot one at that. It makes no sense that HERE needs this checked at the end of July. Apparently, another lazy map update miss. But when you least expect it, HERE strikes again. 😊
        Another interesting HERE aspect of this route is related to WP1. The El Jo Motor Inn (circled below) closed down 5-years ago:
        The OSM base map gets it. It has since reopened (3-years ago) under a major hotel chain with a completely different name:
        Back to avoidances.... Again, it makes your life easier to know where you're going and control everything yourself with WP's. Using set avoidances in any navigation SW can lead to undesirable effects.
          Yes, I did.
          But there are a lot of streets to take (I know this area), and not that detour via Cologne.
            Yes, I did.
            wrote last edited by Brian McG
            @Jörgen if it has to avoid "Highways" then via Colonge is the option OSM works out as the best route on MRA
            your perception of what is & is not a highway will differ to OSM's
            plus MRA messes about with the settings for the OSM routing calculator, so what you get can be hugely unexpected & different to what the OSM site may show
            • What is this? (Basic account)
            • Carpuride scherm vast
              303
            • Export To My Nav 5 Fails
              Mzokkundefined
              Nick Carthewundefined
              2.7k
            • Updated beta! 5.2.1 (486)
              426
            • Three new scenic routes in southern England
              richtea999undefined
            • What is this red line
