  4. Different paths between TT and Here algorithms
6 Posts 4 Posters 960 Views 2 Watching
  • Corrado Miniati 0
    Corrado Miniati 0
    Corrado Miniati 0
    wrote on last edited by Corrado Miniati 0
    All things being equal on the Route Planner, Here takes me down a route that isn't the fastest, while TT shows me the correct route.
    Why does this happen?
    • Leike Lodiers
      They are different card manufacturers and there for the roads style can be different. You can use the compare or the disable seasonal closing option in the right menu to see if you can bring the routes together till they are the same. When you use the openstreetmaps you will see they have a different route. It's all in the design of the road and the class the where given.
      • Corrado Miniati 0
        Corrado Miniati 0
        Corrado Miniati 0
        Hi Leike, thanks for the feedback.
        In fact, with Here by activating the "disable seasonal closing option," the route aligns with the TT, which was correct because it was traveled yesterday and was open.
        In this case, Here's seasonal closing's database isn't up to date.
        • Aiello antonino
          The same problem you have with Garmin navigators, except that here you can disable seasonal closures, while you can't do this with the ZUMOs...
          • Corrado Miniati 0
            Corrado Miniati 0
            Corrado Miniati 0
            the fact that it is activated in itself would not be a problem if it were updated and reliable, but it creates discomfort if it is not
            • RainerT
              RainerT
              RainerT
              Activate the Traffic layer and Zoom in. You will be able to recognize the reason for the closure. In Most cases.
              Rt
              RainerT
              RainerT
              Corrado Miniati 0
              Corrado Miniati 0
                2.6k
                2.6k
              • Seizoensafsluitingen
              • Elektrisch voertuig
                Arno van Lochem - Senior RX
                806
              • Eerste keer MRA met Android auto, een wat mindere ervaring
              • Altitude numbers size
              • 5 dagen Harz.. 2 problemen met AA
              • Hoe kan ik in één route een stuk met en een stuk zonder snelwegen plannen
