  3. MRA + Sygic (with Waypoints) in 2025?
5 Posts 4 Posters 1.5k Views 2 Watching
  • mcrustk2gmail.comundefined Offline
    mcrustk2gmail.com
    Re: Sygic works with GPX import again
    I have referenced an old forum thread above, im trying to export a route with about 15 waypoints (set as ALL hand symbols 'Via'). Im exporting as GPX1.1 and opening in Sygic (latest version).
    Sygic opens and shows the route but no waypoints, has anyone solved this yet or is Sygic no good with MRA?
    Thanks.
    mcrustk2gmail.comundefined 1 Reply Last reply
    • mcrustk2gmail.comundefined mcrustk2gmail.com
      Thanks.
      mcrustk2gmail.com
      @mcrustk2gmail-com
      MRA (With waypoints) > Sygic 2025 - Solved!
      So after the whole night in VSCode trying to work out why the GPX file XML was not being interprited for waypoints in Sygic, and after numerous forum posts, I have a solution!
      Step 0: Download and create a free account with the Garmin Tread app
      Step 1: Create your route in MRA with waypoints
      Step2: Download/Share the GPX from MRA and open in Tread (you can do this in one motion if in the mobile app)
      Step 3: Check your waypoints show in Thread, then just click 'Share GPX' and open with Sygic (again if mobile you can do this in one motion 'open with' rather than messing with file downloads).
      Thats it! All works, my big route now shows all waypoints in Sygic.
      I can only assume (without finding the XML culprit) that the MRA export is not perfect (matching the schema definition for GPX), given Thread is by Garmin, their app must clean it up and re-exports in a cleaner format that Sygic can read!!
      Sorted, enjoy MRA & Sygic.
      • Spiliundefined Offline
        Spili
        wrote on last edited by Spili
        Yeah. It is very complicated to export GPX MRA --> Sygic.
        Also tried Tread and it work ok.
        No idea what is wrong with MRA GPX File.
        Planing route in MRA. Exporting GPX to Tread. Then exporting GPX to Sygic.
        Annoying 😕
        Just check the sizes.
        Same track with waypoints.
        • Nico Beundefined Offline
          Nico Be
          This doesn't work for me.
          I have an MRA file exported in gpx 1.2.
          I followed your procedure, but it doesn't work.
          • Léon Hassingundefined Offline
            Léon Hassing
            The TS exported the route to GPX 1.1. Maybe that is the issue for you?
            Léon Hassing
            Nico Beundefined
            Nico Be
            Spiliundefined
            Spili
            mcrustk2gmail.com
              Mart gundefined
              Mart g
              26
              33
              1.5k
            • Expand
              Martin Woodfordundefined
              Martin Woodford
            • Sharing Routes and Tracklogs
              KevN1k 0undefined
              KevN1k 0
            • Allow Roadbook PDF Attachments for MRA Routes
              Meesterundefined
              Meester
              398
              Herman Veldhuizenundefined
              609
            • MRA Routeplanner Favorieten Permanent op kaart?
              BertMundefined
            • Question regarding how road closures are handled in MRA NN version 5.2
