  4. Next beta 5.0.0(426) And SilverFox problems
13 Posts 3 Posters 120 Views 3 Watching
  • Lluis Arasanz
    Hi,
    I'm using a remote device as controller for Next, but I see some misfunctions or errors.
    To replicate at home I use a Bluetooth keyboard to simulate inputs.
    In navigation screen if I open the menu and select ‘up’ arrow, instead of select 'stop navigation', highligh disapears, until i press 'down' arrow or again up arrow to reach configuration icon. After I reach configuration icon, up and down highlights every menu option.
    If I use left arrow on any menu item, all items upwards are not highlighted until I reach configuration Icon.
    Also, I noted that when I Try to stop navigation, selecting item on menu, I do it and also accept question about “sure?” … but popup about “restart navigation?” Cannot be cancelled or accepted in any way, only by screen touch.
    I try also “standard input” and behavior is the same.
    Not sure if this replicates on public release
    I’m trying to do a video to show it
    • BMW F750GS
    • Lluis Arasanz
      Here is a video
      https://drive.google.com/file/d/18mtcEyTg66X_-Ti3nFYLhtH6gm6pO5oF/view?usp=drivesdk
      • BMW F750GS
      • CD130
        Same experience here on an iPhone and a bluetooth keyboard. It has nothing to do with SilverFox.
        • CD130 CD130
          @CD130 I have a question for you:
          If you open MyRoute first and then you turn on Keyboard, MyRoute crashes when Keyboard connects to phone with a black screen and there is nothing to but force close app?
          I detect this behavior, but I don not know if it's a problem of MyRoute or my phone.
          • BMW F750GS
          • CD130
            Sure, I enabled the keyboard in several places within the MRA app (it connected automatically). I noticed that the on-screen keyboard kept disappearing and the app itself didn’t crash.
            I’m using an iPhone 16 Pro and a Logitech Bluetooth keyboard. Which phone and Android version are you using? That might be useful information for the app developers.
            • Lluis Arasanz
              I'm using Samsung A14 device and Android 14.
              When I use bike controller, all is fine in connection, but if I use a Bluetooth Keyboard, not.
              Is MyRoute is started, on main screen or on navigation screen, MyRoute becomes a black screen. If I turn on MyRoute after connect my keyboard, all works fine.
              But, perhaps is my device. I comment out only after knowing you also use a BT Keyboard.
              • BMW F750GS
              CD130 1 Reply Last reply
              • Lluis Arasanz Lluis Arasanz
                @Lluis-Arasanz Just tested with Remotec One (Bluetooth remote on my motorcycle) and found the same problem. Created a ticket and referred to this topic.
                • CD130 CD130
                  @CD130 Perfect.
                  I'll check on motorcycle when connecting remote controller to phone, testing if I have MyRoute-app opened before or no.
                  Thanks
                  • BMW F750GS
                  • CD130
                    @Corjan-Meijerink Hi, are you able to reproduce this issue? Otherwise I can record a few videos and share them with Rob. When you go to the main menu, choose 🔍 and use the left and right arrows on the Bluetooth keyboard, things go wrong as well. Just tested in 5.0.1 430. Hopefully you can fix it in the future.
                    • Lluis Arasanz
                      Hi,
                      This problem does not reproduce on Android if my "bluetooth device" is not a Keyboard. Perhaps has some interaction with Keyboards Issue that are corrected on 5.0.1. I'll check it when update available to Android.
                      • BMW F750GS
                        I believe these issues will be solved in the 5.0.1 update 😃
                        Let me know once it's available!
                        • CD130
                          @Corjan-Meijerink oh, that is good news. It is still present in 5.0.1 - 430, is that correct?
                            Yes. Made some changes today.
                            Will be in the 432 build.
                              Marcel Versluis
                              Marcel Versluis
                              Parantapa
                              Parantapa
                            • Select friends problem
                            • Android Auto TFT
                            • Route punt overslaan
