  4. [Android Auto] GPS indicator moves jerky (V5 424)
11 Posts 5 Posters 114 Views 4 Watching
    Today i noticed the movement of the GPS/Position indicator was jerky. In a earlier V5 beta version it was smooth. Just as in older versions.
    It was also jerky when no route was active.
    Could this be caused by the changes in the autozoom behaviour?
      What exactly does "jerky" means in this context?
      I'm not sure what the explanation for the behavior could be.
        Instead of constant smooth movement. It jumps. But not constant.
        For a few seconds is movement is smooth. Then it stops moving and a second (or two) later it jumps to correct position. Al this time it stays on the routeline/road.
        Mostly multiple jumps and then a short period of smooth movement.
        It looks like the map jumps and the indicator reacts to it. In other words the indicator keeps it postion related to the screen pretty well.
        I hope this helps you.
          @M.-Schrijver
          Yes, I can also confirm that, perhaps also in connection with an imminent illustration at a traffic light intersection or roundabout if you really have to stop while driving, and that a little longer than the app thinks !!
          iPad 9. Gen iOS 26.3.1a / iPhone 16e iOS 26.3.1a / iPhone Xr iOS 18.7.7 / PC mit MS Win11 /❗️MyRoute-App im Cradel und Remotek-One❗️ Info zu MRA & Remotek One
            I made a short video of this problem.
            The video shows MRA on the smartphone but on Android Auto it looks the same.
            https://youtube.com/shorts/afbzDobvLh4?feature=share
              Rob Verhoeffundefined Offline
              @M.-Schrijver In your opening post you mention that this happens in build 424. Have you also tested this in build 426? That’s the most recent beta version, which will also be released to the public.
                Today i made a ride with latest version available in the Play Store. That is version you see in the video.
                In my case that means 424. A newer version is not offered to me.
                I just checked the Play Store. Still 424 as latest version
                  @M.-Schrijver You have the latest version, as I understand it. You’ll have to wait until monday for the final Android build… iOS is a bit ahead in the rollout.
                    This issue won’t differ between the versions.
                    If you go to account (in the app) and tap “location settings”, what happens? It almost looks like you denied some location permissions.
                    If you are redirected to the Android location settings, that’s fine. If you see a popup in our app, do tell.
                    Can you check if:
                    • Location permissions are set to “always” (including background)
                    • Google location optimisation is enabled
                      I can and will check this. But......
                      I have changed no settings or permissions between version 4...... and 5.
                      In version 4 this issue wasn't there.
                      • Scottish Biker Abroadundefined Offline
                        wrote last edited by
                        I have exactly the same issues
                        Global Roads, Scottish Soul
                        Exploring Europe on Two Wheels
                        Riding on a tiger 800 xcx . In Europe
                        • Direct inloggen op het forum zonder omweg
                        • Shaping points and Via points
                          Herman Veldhuizenundefined
                        • MRA 5.0.4 (451) Tracklog Pictures - Pictures Addendum Error
                        • automatische upload naar explore.garmin.com
                          Mzokkundefined
                        • Add existing POI to a route?
                          Martin Wilckeundefined
                          Martin Wilcke
                        • Na planning
                          white.mouseundefined
                        • Invisible waypoints
                          Nick Carthewundefined
                        • Some routes opening slow and some fast
                          Nomko Nomdenundefined
                          Nomko Nomden
