  4. Scenic tour A/R info
5 Posts 3 Posters 1.3k Views 2 Watching
  • Corrado Miniati 0
    Corrado Miniati 0
    Corrado Miniati 0
    Hi, I had created a circular tour setting to avoid off roads but then following the tour I found a road that was mixed paved and gravel with challenging sections that put me in difficulty.
    In the case of a mixed road, does the algorithm consider it paved and not off road?
    Thanks a lot
    • Travellexxie
      Probably a map-error. Report it here: https://mapfeedback.here.com/#/report
      MRA Lifetime Gold
      • Corrado Miniati 0
        Corrado Miniati 0
        Corrado Miniati 0
        ok, thanks a lot for the info
        • Corrado Miniati 0
          Corrado Miniati 0
          Corrado Miniati 0
          How often do Here usually update the maps based on the reports received?
            These calculations are not done with HERE @Lex.Kloet.RX 😉
            Reporting them there, will not help.
            @Corrado-Miniati-0 please create a support ticket: myrouteapp.com/support and indicate where the issue occurred. Ideally recreate it with a route from the Routeplanner (select OSM map, set avoid options and show the wrong road is taken).
            Corrado Miniati 0
            Corrado Miniati 0
            • New Zealand Routes
              433
            • Getal in begin logo
            • Naar vorig routepunt
            • Opknippen route in etappes
              Hans777
              Hans777
            • best format to download
