  4. Navigation
Navigation
6 Posts 3 Posters 1.6k Views 2 Watching
  • Ck Hosundefined Offline
    Ck Hos
    We are touring Italy at the moment and MRA is so it and miss. For example we had a simple route planned from the top of lake Como to Como and We were supposed to peel off towards Turin then on to Asti. MRA decided to navigate us back up the opposite side of the lake back to our original start point. Any suggestions šŸ¤”
    • Ck Hosundefined Ck Hos
      Rob Verhoeffundefined Online
      @Ck-Hos said in Navigation:
      Not without reviewing the route you made! Post the url of your route in this topic and ensure that it is set to public.
      Ck Hosundefined 2 Replies Last reply
        Ck Hos
        @Rob-Verhoeff
          Ck Hos
          @Rob-Verhoeff View 'italy day11' in MyRoute-app! https://www.myrouteapp.com/route/open/10698915
          • Rob Verhoeffundefined Online
            Could it be that you didn't pass viapoint 1? If you don't actually 'hit' that waypoint, MRA keeps sending you back until you've drove over it! For the rest shapingpoints 4 and 6 are slightly misplaced. Try to punt them on the road instead of in an building. I certainly would add some more shapingpoints. Try to use as less as possible but as many as needed! Only 8 waypoints on app. 300km is not much!
            I hope you're enyoing your trip
              @Ck-Hos, what @Rob-Verhoeff says is likely what happened. Place your first waypoint some distance into the direction you want to start, to make sure you actually "hit" it , when driving off. The first waypoint is a VIA point (hand-shape) and will not be automatically skipped if you don't hit it.
              Ck Hosundefined
              Ck Hos
              • Starting navigation in the middle o the programmed Route.
                richard 3vundefined
                richard 3v
                Jan Weerheimundefined
                Jan Weerheim
                Reinhard Punzundefined
                Reinhard Punz
                Peter Zehentreiterundefined
                3.1k
              • Duizend bochten
                754
              • Ajouter une station service dans le parcours
                LE DIZES Freddyundefined
                LE DIZES Freddy
              • Crashes na update
                Nick Carthewundefined
