  4. se non sblocco lo smartphone android auto non visualizza il percorso
2 Posts 2 Posters 846 Views 1 Watching
  • MASSIMO66
    MASSIMO66
    MASSIMO66
    Buon giorno,
    se utilizzo Myroute-app con Android auto (sia in moto che in auto) se non sblocco lo smartphone la navigazione non viene visualizzata. Questo non accade con Google Maps. Come posso fare per non dover sbloccare ogni volta lo smartphone?
    Grazie
    • MASSIMO66 MASSIMO66
      Buon giorno,
      Grazie
      @MASSIMO66, I took the liberty to translate your question into English:
      if I use Myroute-app with Android auto (both on the bike and in the car) if I don't unlock the smartphone the navigation doesn't show up. This does not happen with Google Maps. How can I do so that I don't have to unlock the smartphone every time?
      I think you need to add permissions to the app to run in the background. This is something that is done in the OS (Android / iOS?) settings, not in the MRA app settings. Also check the location permissions to be set on Always, and not "when in use", because we have seen in the past that sometimes background use is not qualified as "in use".
      MASSIMO66
      MASSIMO66
      • How to plan correctly
        Christian Feurstein
        Christian Feurstein
        525
      • test Myroute APP
        1.9k
        Jörg Neudert
        Jörg Neudert
        679
        LE DIZES Freddy
        LE DIZES Freddy
        8.0k
