Circle POI beta.gpx
if you save a route as BETA gpx, with also POIs, you import on basecamp, around the POIs there is a circle, what does it mean? I'm new to the garmin world ...!!
This is a specific question about Garmin and Basecamp.
You can get a warning when you get close to a POI while navigating.
The circle in Basecamp indicates where the warning is given.
In Basecamp you can specify this radius in the tab <advanced> in the properties of the relevant POI. -
In Basecamp you can specify this radius in the tab <advanced> in the properties of the relevant POI.@Jack-van-Tilburg
but this "circle" I find it when I import the beta gpx file in basecamp without modifying or touching anything in basecamp -
@Jack-van-Tilburg
but this "circle" I find it when I import the beta gpx file in basecamp without modifying or touching anything in basecamp@Aiello-antonino
The POI's have a radius of 100 meters by default in MRA. But you cannot adjust that in MRA. -
If you use a colored routepoint in MRA, then the circle is added, it has no use at this moment
@Hans-van-de-Ven-MRA-Master
Then there will be no warning in basecamp !? will it be useful in the future? -
Then there will be no warning in basecamp !? will it be useful in the future?Maybe....
Maybe....
@Hans-van-de-Ven-MRA-Master quale è il metodo migliore per fare in modo che il “percorso” fatto su MRA sia perfettamente uguale sullo zumo?
@Aiello-antonino
By correctly placing the route points on the Here map route line
