  3. Tulip Route in Holland?
tulip
14 Posts 5 Posters 2.8k Views 4 Watching
  • Stefan G. Rasmussenundefined Offline
    Stefan G. Rasmussen
    Any of you have a suggestion to the best route in order to see the tulip fields of Holland in late March?
    Kindly Stefan
    Rob Verhoeffundefined Arno 0undefined 2 Replies Last reply
    • Stefan G. Rasmussenundefined Stefan G. Rasmussen
      Kindly Stefan
      Rob Verhoeffundefined Offline
      @Stefan-G-Rasmussen Take a look in the RouteXpert Library. This route, among others, takes you through the flower fields.
      https://www.myrouteapp.com/nl/motor-en-auto-routes/nl/Noord-Holland/295532/21-Bollenstreekroute
      Stefan G. Rasmussenundefined Garry Davisundefined 2 Replies Last reply
        Stefan G. Rasmussen
        @Rob-Verhoeff Thank you my friend, I'll take a look! 👍
          nomkoundefined Offline
          @Stefan-G-Rasmussen
          what will be your starting point?
          the Bollenstreek route is very short, maybe you can combine it with a toure through the "Groene hart" between Alphen aan de Rijn and Uithoorn.
          | MRA Gold Member |
          | MRA Next + Kawasaki Z650 |
          Stefan G. Rasmussenundefined 1 Reply Last reply
          • nomkoundefined nomko
            @Stefan-G-Rasmussen
            Stefan G. Rasmussen
            @Nomko-Nomden I'l start out from Denmark and come into the northert part of Holland...
              @Stefan-G-Rasmussen said in Tulip Route in Holland?:
              ah ok
              just be aware that the so called Bollenstreek is not to be found in the northern part of Holland but in the costal region of South-Holland provence.
              from the northern part of Holland it will be 2-3 houts drive to get there.
              | MRA Gold Member |
                ah ok
                Stefan G. Rasmussen
                @Nomko-Nomden - Yes I'm aware of that, and I do also have acces to another route south of Rotterdam on a island... 🙂
                Stefan G. Rasmussenundefined nomkoundefined 2 Replies Last reply
                  Stefan G. Rasmussen
                  https://www.myrouteapp.com/en/social/route/7382632?mode=share
                    @Stefan-G-Rasmussen Perfect!
                    just 1 sugestion, why not take the route as i marked up:
                    | MRA Gold Member |
                      @Stefan-G-Rasmussen You're taking a "grand tour" through The Netherlands i see 😉
                      | MRA Gold Member |
                        Stefan G. Rasmussen
                        @Nomko-Nomden Yes, and thank you for your suggestion... 🙂
                          Garry Davisundefined Offline
                          Garry Davis
                          @Rob-Verhoeff Thanks for this, me and the wife are going in late April. We have a spare day, so will use this. 👍 👍
                            Kindly Stefan
                            Arno 0undefined Offline
                            Arno 0
                            @Stefan-G-Rasmussen If you want to see the tulip fields, you better follow the Dijk- en Duinroute created by Hans van de Ven. I believe you here find the biggest tulip fields of the Netherlands and it's less touristic then in de Bollenstreek.
                            https://www.myrouteapp.com/en/motor-and-car-routes/nl/Noord-Holland/295518/19-Dijk-en-Duinroute
                            Garry Davisundefined 1 Reply Last reply
                            • Arno 0undefined Arno 0
                              Garry Davis
                              wrote on last edited by Garry Davis
                              #14
                              @Arno-0 Thanks for that. I think I'll stick to the first route, as we don't want to do too much driving. Were based just north of Alphen aan den Rijn, ( Yes, sadly in a car, not on my bike 😢 😢 ) Maybe a route for next time though. 👍👍
                              nomkoundefined
                              Garry Davis
                              Arno 0undefined
                              Arno 0
                              Stefan G. Rasmussen
                                Ruurt Visserundefined
                                Ruurt Visser
                                163
                              • MRA connector - Zumo XT (+SD)
                                Guztundefined
                                Guzt
                                Peter Zehentreiterundefined
                                24
                                20
                                992
                              • Routepunten automatisch overspringen
                                Mister Bundefined
                                Mister B
                                Brian Martinundefined
                                Brian Martin
                              • Symbolen
                                Hans Kragtundefined
                                Hans Kragt
                                Steve Jarrellundefined
                                Steve Jarrell
                              • Offline navigation as of June, 2026 release 5.1
                                Lenny Oundefined
                                Lenny O
