  4. Verrouillage de l'écran
8 Posts 5 Posters 128 Views 2 Watching
  • LE DIZES Freddyundefined Offline
    LE DIZES Freddy
    Bonjour,
    Le verrouillage d'écran fonctionne très bien , mais lorsqu'on appuis sur les 3 points pour avoir le menu , il faut ensuite descendre en bas du menu déroulant pour avoir l'activation du verrouillage écran , serait-il possible d'avoir l'activation juste en dessous de "Arrêter la navigation"
    Pour déverrouiller , le petit cadenas , c'est parfait
    Freddy
    Con Hennekensundefined Rob Verhoeffundefined 2 Replies Last reply
    • LE DIZES Freddyundefined LE DIZES Freddy
      Bonjour,
      Freddy
      @LE-DIZES-Freddy, you are completely right. This is typically a feature that you want to have available during a ride, without stopping for it.
        Bonjour,
        Freddy
        Rob Verhoeffundefined Offline
        @LE-DIZES-Freddy My French is a bit rusty, hence the reply in English 😉
        I completely agree with you. Moving this option to a higher position in the list would avoid the need to scroll. Upvote!
        Routelab on MacBook Air & iMac (Sequoia & Monterey)
          LE DIZES Freddy
          je vois que c'est fait , merci le verrouillage est maintenant juste en dessous "Arrêter la navigation"
          Merci beaucoup
            Merci beaucoup
            @LE-DIZES-Freddy you are welcome 😉
            And long pressing the menu button will also enable the lock screen!
              @Corjan-Meijerink man, there are so many screen functions, short press, long press, pop ups, options. I don't think I will ever be able to remember them all. I guess this happens when you try to satisfy every user wish and whim. Eventually it will get too complicated.
              Corjan Meijerinkundefined Con Hennekensundefined 2 Replies Last reply
                @RetiredWingMan agree 😉
                Good thing is that generally long presses somewhere are only a shortcuts to achieve something that can otherwise be done with more clicks.
                  @RetiredWingMan, in general:
                  tap / click = open or toggle something
                  long press = do something (immediate action)
                  This is a philosophy used many UI designers.
                  LE DIZES Freddy
                  • MRA Bewertung 5 : 5 stimmt das was meint ihr dazu ?
                    259
                  • Multi day plan | Hotel stop time doesn't get added
                    Nomko Nomdenundefined
                    Nomko Nomden
                  • MRA E-Learning
                  • WIJZIGINGEN IN ROUTE
                    Boštjan Kreutzundefined
                    Boštjan Kreutz
                  • Can't type in (Route-information) (Description )
                  • Start niet op, blijft hangen
                    white.mouseundefined
                    1.3k
                  • VERANDERING ROUTE NA AFSLUITEN
                  • MRA on iPhone not voicing directions during podcasts
