  4. Moving Map without Accidentally Adding Unwanted Waypoint
9 Posts 4 Posters 1.5k Views 3 Watching
  • David Howarth Offline
    David Howarth
    I am using MRA on a Macbook with Trackpad and I am getting fed up of accidentally adding a Waypoint when just trying to move the map on the display. I know if I hold down the trackpad and move the cursor the map moves/scrolls (which is what I want to do) but so many times I accidentally click the trackpad which the just adds an unwanted waypoint which I then have to undo. This is so frustrating. I can't see any tool to allow me to scroll/move (like in Basecamp) and I have tried various combinations of holding down a key but nothing seems to work. Does any body know of a way I can move the map view without inadvertently adding a waypoint Thanks
    Dae 0 1 Reply Last reply
    • David Howarth David Howarth
      Dae 0 Offline
      Dae 0 Offline
      Dae 0
      The same goes for the search box. I want to search for something and have the map move to where it is, not add a waypoint to the route.
      Dave J 0 1 Reply Last reply
      • Dave J 0 Offline
        Dave J 0 Offline
        @David-Howarth In the Page Menu, select ‘Place Waypoint Button”:
        You will then see a cursor which you place where you want to insert a waypoint by moving the map and then select the button ‘Place Waypoint’.
        I use an iPad for most of my route planning and this stops the inadvertent waypoint insertion when touching the map. You can also use the ‘Lock Waypoints Button’ - See reply below.
        iPhone 15 Pro
        • Dae 0 Dae 0
          Dave J 0 Offline
          Dave J 0 Offline
          @Dae-0 Use the lock Waypoints button. When you search, the map will move to where you have searched without inserting a waypoint.
          Whilst adding waypoints is locked, you can still add POIs as waypoints through the Points of Interest Menu if they are selected on the screen.
          iPhone 15 Pro
          David Howarth Dae 0 2 Replies Last reply
          • Dave J 0 Dave J 0
            David Howarth
            wrote on last edited by David Howarth
            @Dave-J-0 Thank you Dave, that has really worked for me and will now save me hours of frustration.
            Incidentally, I too was a Blood Biker (with Derbyshire Blood Bikes for 6 years) and actually moved over to Shropshire, Staffordshire and Cheshire Blood Bikes in 2021 but unfortunately (due to ill health) did not manage to continue. My brother in law is still a volunteer with Shropshire, Staffordshire and Cheshire Blood Bikes, usually using the bike from Uttoxeter. Small World......
            • Dave J 0 Dave J 0
              Dae 0 Offline
              Dae 0 Offline
              Dae 0
              @Dave-J-0
              Thanks. That’s helpful, even if it’s a bit of a fudge.
              What would be handy would be to change the search box and, for example, allow shift+enter to search without adding to the route.
              In nearly all cases that I’m searching, I’m looking for an area or general thing, rather than a specific point that I’m immediately going to add to the route.
              Stanisław 1 Reply Last reply
              • Dae 0 Dae 0
                @Dave-J-0
                Stanisław Offline
                Stanisław Offline
                Stanisław
                @Dae-0 I prefer the "Ask for waypoint name" parameter - in this case I can press ESC or use Cancel button and avoid placing unnecessary waypoint:
                Staszek
                • Stanisław Stanisław
                  Dae 0 Offline
                  Dae 0 Offline
                  Dae 0
                  @Stanisław That’s probably a better workaround as it avoids lock-search-unlock every time.
                  I’d still like an option though similar to my suggestion above, or even a tick box to stop the auto creation of waypoints when searching.
                  Maybe I’m using MRA differently to everyone else, except my wife as she does 90% of our tour planning also finds the auto-add annoying.
                    Dave J 0 Offline
                    Dave J 0 Offline
                    @David-Howarth Indeed a small world. Might 'bump' into you sometime.
                    iPhone 15 Pro
                    Stanisław
                    Stanisław
                    Dae 0
                    Dae 0
                    David Howarth
                    David Howarth
                    • Elektrisch voertuig
                      jan rodeyns
                      jan rodeyns
                    • opslaan naar plantomtom
                    • Update 5.2.2 - Quick fix
                      1.2k
                      Ioan Dragulescu
                      Ioan Dragulescu
                      10.2k
                    • Waypoint list for a long route ( ~50 t0 100 routing points) will not be show on the Android auto ridernav screen
                      Fridjof
                      Fridjof
                    • Welke instelling
                      247
                    • Carpuride W702 icm Carplay
                      17.5k
                      286
