  4. Import Coordinates/Excel data
17 Posts 4 Posters 139 Views 2 Watching
  • GT JWR Offline
    GT JWR Offline
    Have searched and couldn't find previous history - is it possible to import coordinate data sets, from an excel spreadsheet, for example, into the planner?
    • GT JWR GT JWR
      @GT-JWR
      Yes you can. create a csv file with the data like this
      -4.4740426540375,57.522252802735,"The Singleton of Glen Ord Distillery, Visitor Centre & Whisky Shop",""
      Import the file as a POI file.
      GT JWR 2 Replies Last reply
        @GT-JWR
        GT JWR Offline
        GT JWR Offline
        @Hans-van-de-Ven-MR-MRA thanks.
          @GT-JWR
          GT JWR Offline
          GT JWR Offline
          @Hans-van-de-Ven-MR-MRA I have successfully created and imported a *.csv file into POI.
          However, I am not having any success with the coordinates showing up in/along the planned route - what am I missing?
          For example, the 4th set of coordinates should show up where the yellow highlighted circle is...5ccaa81c-3e28-4485-8676-42a7d84f249b-image.png
          • GT JWR GT JWR
            @GT-JWR
            Add the name like in the example
            GT JWR 1 Reply Last reply
              @GT-JWR
              GT JWR Offline
              GT JWR Offline
              @Hans-van-de-Ven-MR-MRA when I click on 'Add', it simply wants me to re-import the file - it does not add it to the route map. 🤷
              • GT JWR GT JWR
                RetiredWingMan Offline
                @GT-JWR use the 3 bar menu (top left side) to display points of interest.
                  GT JWR Offline
                  GT JWR Offline
                  wrote on last edited by GT JWR
                  @RetiredWingMan I did...see this image above. 83b2166f-5fbb-4bcc-b15c-354c4937ef18-image.png
                  Clicking on 'Add' does nothing except wanting to re-import the file - absolutely no coordinates from that file get added to the map I am wanting to add them to. 🤷 Something's missing?
                  • GT JWR GT JWR
                    @GT-JWR when you go back to the map your POIs should appear. You may have to zoom in a bit for them to appear.
                    • paul69 Offline
                      paul69 Offline
                      hi @GT-JWR
                      i have just used the top co-ordinate that you put in the screen shot
                      29.812298226572583, -95.7728516190678
                      and this was the rsult when i added it as a POI, obviously the blue square, i just named it test for a sample.
                      so this seems to work for me.
                      K1600 GTL
                      Oukitel RT3
                      iPhone 13 Pro, carpuride 702b
                      • paul69 paul69
                        hi @GT-JWR
                        GT JWR Offline
                        GT JWR Offline
                        @paul69 @RetiredWingMan - appreciate the advice.
                        Perhaps I need to clarify, to make sure I understand what takes place vs what is supposed to take place.
                        If I have a *.csv file, that has 20 coordinates it it, for example, what are the steps? My understanding of what should happen:
                        • click on POI, which opens 3 options.... Search, Manage & Library.
                        • go to Library, click on Add...select the *.csv file, and it imports
                        • place a check in the box, and ALL coordinates in that file should now show on the map.
                        Is this correct?
                        None of the coordinates show up, even when zoomed in.
                        According to the Manual in loading POI's, it should work.
                        • paul69 Offline
                          paul69 Offline
                          hi @GT-JWR
                          apologies but I am unable to help any further, I do not normally use this function, I only tried it to see if it worked for me.
                          somebody with a lot more experience than I will be along to help you, of that, I am sure.
                          K1600 GTL
                          Oukitel RT3
                          • GT JWR GT JWR
                            Is this correct?
                            wrote on last edited by RetiredWingMan
                            @GT-JWR as you can see in the screen shot below, I added a POI list of distilleries in Scotland. When I zoom in sufficiently, they appear on the planning map. The only thing I can think of is that your file of POIs does not include all of the data required to properly create the POIs. You did not replicate the example in June of the first responses. Your missing a name for the POI as well as a trailing text field.
                              GT JWR Offline
                              GT JWR Offline
                              @RetiredWingMan I will input names and see if that brings me success! Thanks.
                              • GT JWR GT JWR
                                @GT-JWR
                                Download this file as: POI.csv
                                https://www.facebook.com/share/p/BPkBZXz1GWxdUjU1/
                                And then upload it as POi
                                  @GT-JWR
                                  GT JWR Offline
                                  GT JWR Offline
                                  @Hans-van-de-Ven-MR-MRA I did that - the link opens MRA directly, and all POI's are there.
                                  So then out of curiousity, I went to the 'Files' on that FB page, found this file, Afsluitingen_NLD_20220118.csv, and when saving to my PC, noticed it was a 'CSV UTF-8' file. Thinking this might have something to do with the issue I'm having, I also saved it as a simple '*,CSV' file.
                                  Then added both to my POI list, both opened up and showed as expected.
                                  Perhaps I have something wrong with the file I am trying to load?
                                  ...tried to copy file here, saying I don't have enough privelages...will try to copy in a 2nd reply.
                                  • GT JWR GT JWR
                                    GT JWR Offline
                                    GT JWR Offline
                                    @Hans-van-de-Ven-MR-MRA ...well, appears I cannot attach the file... 😞
                                    • Paar onduidelijkheden.
                                      165
                                    • Wegwerkzaamheden worden niet goed toegepast
                                    • Route app reageert niet
                                      Erik Schouten
                                      Erik Schouten
                                      Huibertus
                                      Huibertus
                                    • Blauwe routelijn lijft in Carplay wit
                                      28
                                      61
                                      7.0k
