  4. Import Coordinates/Excel data
17 Posts 4 Posters 139 Views 2 Watching
  • GT JWRundefined Online
    Have searched and couldn't find previous history - is it possible to import coordinate data sets, from an excel spreadsheet, for example, into the planner?
    • GT JWRundefined GT JWR
      @GT-JWR
      Yes you can. create a csv file with the data like this
      -4.4740426540375,57.522252802735,"The Singleton of Glen Ord Distillery, Visitor Centre & Whisky Shop",""
      Import the file as a POI file.
      GT JWRundefined 2 Replies Last reply
        @GT-JWR
        @Hans-van-de-Ven-MR-MRA thanks.
          @GT-JWR
          @Hans-van-de-Ven-MR-MRA I have successfully created and imported a *.csv file into POI.
          However, I am not having any success with the coordinates showing up in/along the planned route - what am I missing?
          For example, the 4th set of coordinates should show up where the yellow highlighted circle is...5ccaa81c-3e28-4485-8676-42a7d84f249b-image.png
            @GT-JWR
            Add the name like in the example
              @GT-JWR
              @Hans-van-de-Ven-MR-MRA when I click on 'Add', it simply wants me to re-import the file - it does not add it to the route map. 🤷
                @GT-JWR use the 3 bar menu (top left side) to display points of interest.
                  wrote on last edited by GT JWR
                  @RetiredWingMan I did...see this image above. 83b2166f-5fbb-4bcc-b15c-354c4937ef18-image.png
                  Clicking on 'Add' does nothing except wanting to re-import the file - absolutely no coordinates from that file get added to the map I am wanting to add them to. 🤷 Something's missing?
                    @GT-JWR when you go back to the map your POIs should appear. You may have to zoom in a bit for them to appear.
                    • paul69undefined Offline
                      hi @GT-JWR
                      i have just used the top co-ordinate that you put in the screen shot
                      29.812298226572583, -95.7728516190678
                      and this was the rsult when i added it as a POI, obviously the blue square, i just named it test for a sample.
                      so this seems to work for me.
                      K1600 GTL
                      Oukitel RT3
                      iPhone 13 Pro, carpuride 702b
                      • paul69undefined paul69
                        hi @GT-JWR
                        @paul69 @RetiredWingMan - appreciate the advice.
                        Perhaps I need to clarify, to make sure I understand what takes place vs what is supposed to take place.
                        If I have a *.csv file, that has 20 coordinates it it, for example, what are the steps? My understanding of what should happen:
                        • click on POI, which opens 3 options.... Search, Manage & Library.
                        • go to Library, click on Add...select the *.csv file, and it imports
                        • place a check in the box, and ALL coordinates in that file should now show on the map.
                        Is this correct?
                        None of the coordinates show up, even when zoomed in.
                        According to the Manual in loading POI's, it should work.
                          hi @GT-JWR
                          apologies but I am unable to help any further, I do not normally use this function, I only tried it to see if it worked for me.
                          somebody with a lot more experience than I will be along to help you, of that, I am sure.
                          K1600 GTL
                          Oukitel RT3
                            Is this correct?
                            wrote on last edited by RetiredWingMan
                            @GT-JWR as you can see in the screen shot below, I added a POI list of distilleries in Scotland. When I zoom in sufficiently, they appear on the planning map. The only thing I can think of is that your file of POIs does not include all of the data required to properly create the POIs. You did not replicate the example in June of the first responses. Your missing a name for the POI as well as a trailing text field.
                              @RetiredWingMan I will input names and see if that brings me success! Thanks.
                                @GT-JWR
                                Download this file as: POI.csv
                                https://www.facebook.com/share/p/BPkBZXz1GWxdUjU1/
                                And then upload it as POi
                                  @GT-JWR
                                  @Hans-van-de-Ven-MR-MRA I did that - the link opens MRA directly, and all POI's are there.
                                  So then out of curiousity, I went to the 'Files' on that FB page, found this file, Afsluitingen_NLD_20220118.csv, and when saving to my PC, noticed it was a 'CSV UTF-8' file. Thinking this might have something to do with the issue I'm having, I also saved it as a simple '*,CSV' file.
                                  Then added both to my POI list, both opened up and showed as expected.
                                  Perhaps I have something wrong with the file I am trying to load?
                                  ...tried to copy file here, saying I don't have enough privelages...will try to copy in a 2nd reply.
                                    @Hans-van-de-Ven-MR-MRA ...well, appears I cannot attach the file... 😞
                                    GT JWRundefined
                                    paul69undefined
                                      Peter Zehentreiterundefined
                                      706
                                    • Updated beta! 5.2.1 (486)
                                      white.mouseundefined
                                      218
                                    • MRA 5.2.1 - 486 CarPlay Display Issue When route started on iPhone
                                      GT JWRundefined
                                    • Unknown symbol
                                    • Navigation Next versus Routeplanner
                                      Ron 33undefined
                                      Ron 33
                                    • Hoogte meters in Navigatie
                                    • MRA en Garmin GPSmap 60CSx
                                      Gerard Wullinkundefined
                                      Gerard Wullink
