  4. Multiple route export possibility wanted
7 Posts 3 Posters 1.6k Views 2 Watching
  • Gerard Wullink
    Gerard Wullink
    Gerard Wullink
    We organised a tour through Norway which holds 23 routes. When "Exporting" these routes to the GPS using the connector, you would have to do that one by one.
    18 participants, 23 routes = 414 times:
    • Open a route,
    • Click Export
    • Click Export
    • Click Open route
    • Click select device
    • Click the selected device
    • Click Export to Device.
    Thats exactly 2898 clicks to go.
    Requests:
    • Make the Connector remember the last device type (GPX1.1 RTP) etc).
      Possible solution: Store the default device-type (same choices as Select device in connector) in the user profile. Change connector so it can be called with this default device (parameter). Very nice to have for everyone.
    • Create a possibility to export multiple routes to the same device from a overview screen (as you already do with move, save as and remove). Even if this was limited to a certain number of routes it would be of great help.
    HABVEN aka MrMRA Herko ter Horst 2 Replies Last reply
    • Gerard Wullink Gerard Wullink
      • Open a route,
      • Click Export
      • Click Export
      • Click Open route
      Requests:
      @Gerard-Wullink
      It has been requested many times and is on the ToDo list for major maintenance.
      Gerard Wullink 1 Reply Last reply
        @Gerard-Wullink
        Gerard Wullink
        Gerard Wullink
        Gerard Wullink
        wrote on last edited by Gerard Wullink
        @Hans-van-de-Ven-MR-MRA Nice. Is a list of wishes/issues, at least which are approved to be cretaed/fixed, available for users? Would be handy to know and saves tickets too
          @Gerard-Wullink
          No, not yet available to users, the development team is collecting these, they will publish them in due course and then prioritize and decide what can be achieved.
            • Open a route,
            • Click Export
            • Click Export
            • Click Open route
            Requests:
            @Gerard-Wullink Until those changes have been made, it's probably a lot less work not using "Export", but "Save as" instead. This does support saving multiple routes at the same time and will give you a zip-file containing GPX files, which you can send by e-mail (or any other mechanism you like) to your fellow travellers.
              Gerard Wullink
              Gerard Wullink
              Gerard Wullink
              @Herko-ter-Horst Hello Herko, I know the Save as option. At our MC we noticed that when using a Zumo 3/5series the result on the gps differs between the export and save as function.
              Apparently the import/conversion of a saved gpx file, which is placed in the GPX dir on the GPS, differs from the export function.
              If you use a saved gpx file containing Track, Route and POI the Zumo3/5 does not show hard waypoints other than Start and End of the route. If you use Export it will show them.
                Gerard Wullink
                Gerard Wullink
                Gerard Wullink
                @Gerard-Wullink note Navigators 4/5/6, XT/XT2 work fine using the Save as method. Just the Zumo 3/5 fails.
                Gerard Wullink
                Gerard Wullink
                • Custom POI color and icons
                • A11 Making the Algorithm More Visible – Overview and Planner File
                • File / Creation date
                • F003 POI Folder & group missing in the app
                • F005 Menu covered
                • File en omrijden
                • Geen pictogram van een motor
