  4. Track or non track for planned route
4 Posts 3 Posters 986 Views 1 Watching
  • roland reay
    roland reay
    roland reay
    Hello ladies and gentlemen when planning a route and exporting to the sat nav i have two options for example ,Strasbourg to spa and track strasbourg to spa which one is the best option thankyou
    Lynchy67 1 Reply Last reply
    • roland reay roland reay
      Lynchy67
      Lynchy67
      Lynchy67
      @roland-reay
      In my opinion a Route with Waypoints (Shaping and Via) is the way to go.
      A Track has limited appeal for me.
      My preferred road types are the twisty country lanes (The ones with a bit of grass/moss in the middle.)
      I try to string as many of these together as possible but inevitibly I have to endure some major roads along the way.
      To negate the chance of the algorythm making choices for me I put at least one waypoint on every road I plan to ride on.
      I also use Street View a lot in the planning stage and actively check for Closed Roads using Traffic (Gold).
      I also plan Fuel Stops in advance based on wether im useing the 1200 Tiger Rally Pro or the Tenere 700 (16 Litres EEK!).
      • roland reay
        roland reay
        roland reay
        Ok thanks for the reply but what does a track actually give you regarding planning and riding the non track route thanks again
        Leike Lodiers 1 Reply Last reply
          @roland-reay Depending what navi you use. When you use a garmin I would prefer to load the track on it. Then let the garmin make a route of you're track. You can then load the route that is the same as the track. You also can load the track and make it visible and then follow the track which doesn't change and with no point to point navigation.
          roland reay
          roland reay
          Lynchy67
          Lynchy67
            152
            Ruud Bijkerk
            Ruud Bijkerk
          • Route exporteren uit beta
            Johan 5q
            Johan 5q
            125
          • iPad - zooming out
            Big Al 1
            Big Al 1
          • Website update - Trip book PDF, route lock for collaborators, a close button in the planner and more
