  3. Garmin ZUMO XT2 Import Waypoints
5 Posts 3 Posters 1.6k Views 2 Watching
  • Mat Jonesundefined Offline
    Mat Jones
    Sorry if this is in the wrong area, I have created a route I want to take from from start to finish with 15 way points.
    When I export this route “GPX 1.1” and import this into Garmin Tread I then go onto my ZUMO and open the route.
    I can not for the life of me get the map to show all the way points and then to hit start and it direct me to next waypoint instead it just maps a route using the way points it asked me where I want to go to next, there is no option to go to the next labeled waypoint.
    Thank you in advance
    Taff
    • Mat Jonesundefined Mat Jones
      Taff
      @Mat-Jones
      Please share the url of the route here. Make sure it is set to public
      Mat Jonesundefined 1 Reply Last reply
        @Mat-Jones
        Mat Jones
        @Hans-van-de-Ven-MRA-Master https://www.myrouteapp.com/route/open/8622355
          @Mat-Jones
          A route of 427 KM with only 13 shaping points is asking for problems. Depending on the environment, we maintain a shaping or via point every 4 to 5 KM.
          Also make sure that the points are positioned correctly on the route line, to avoid surprises.
          If your route is technically well constructed, it will be processed well by your XT2.
          Please note that if you use the Tread app, you use the GPX 1.1, but it is best to set the route via the connector or save as on your XT2. Reason: the Tread app is essentially the Garmin Explore website and Garmin Explore does not handle routes well, but it does handle tracks
          • nomkoundefined Offline
            Normally i place a tracking point/waypoint after each turn i have to make (left/right turn) at intersections or junctions. Thus will create a route with a lot of waypopints/tracking point, but you won't go wrong with the route itself since you "force" MRA to plot the route you crerates like that.
            | MRA Gold Member |
            | MRA Next + Kawasaki Z650 |
            nomkoundefined
            Mat Jonesundefined
            Mat Jones
            • After coffee, MRA does not continue from where we left off.
              white.mouseundefined
            • Mileage to destination versus waypoint to waypoint
              Eric Colón 3 0undefined
              Eric Colón 3 0
            • No display of current speed and linit speed after update
              D Griffinundefined
              D Griffin
            • MRA tijdens een trip door de Eifel
              Travellexxieundefined
            • Route ging prima; nog wel twee wensen!
              Thomas Neumeyerundefined
              Thomas Neumeyer
              4.8k
            • volume loopt terug
              supergundefined
            • Herschikken routepunten
              RobdHundefined
              RobdH
