  3. BMW Connected
BMW Connected
14 Posts 6 Posters 3.0k Views 2 Watching
  • TorqueRider TorqueRider
    @Brian-Marchand-0
    It's not entirely clear to me what your question is.
    When you export the route you have several choices with which you can do that.
    Connected is obvious to me, but there are more apps that you can choose from. (depends on your smartphone. this is an iPhone image)
    MR-1600GTL
    MR-1600GTL
    MR-1600GTL
    @Jack-van-Tilburg When I open the route in the App, I don't see the different options that are shown in your picture. So I want to direct import the route in Connected, yet to me that's not an option on my Samsung S23 Ultra.MRA-App 1.jpg
    When I now click on open the actual navigation starts in the MRA Navigation screen.
    • MR-1600GTL MR-1600GTL
      @MR-1600GTL
      Use:
      Then choose GPX 1.1 and Export
      • MR-1600GTL
        MR-1600GTL
        MR-1600GTL
        Hi Jac,
        Thxs for the swift reply.
        I have seen the Download button, yet as shown on the earlier screen of earlier posters as well as done by Corjan it looks there should be a way as where I would/should be able to take away the download step and open directly into the Connected App of BMW. Or is taking away that step only reserved for Apple iOS users, as the print screen I responded to was a iOS screenprint as where mine is a Android.
          Hi Jac,
          @MR-1600GTL
          I do indeed have an iOS. After I choose "Export" I can select the ConnectedApp as dol and then enter the import screen of the ConnectedApp.
          That is not entirely direct either. But I don't know if it works differently on Android.
          MR-1600GTL 1 Reply Last reply
            @MR-1600GTL
            MR-1600GTL
            MR-1600GTL
            MR-1600GTL
            @Jack-van-Tilburg Hi Jack, Thxs again. I checked the Dutch webinar of yesterday (feb. 6th) and indeed around the 27th minut Corjan is doeing as what you described. I was under te impression that this could be done without the import part, yet now indeed I see he first downloads the file and than exports it to the respective app. Thanks for clearing this out for me.
            Will the BMW App work better with TomTom , OpenStreetmap or Garmin maps?
            Hans van de Ven MR.MRA TorqueRider 2 Replies Last reply
              @MR-1600GTL
              TomTom and max 50 shaping points per route
                @MR-1600GTL
                After you have imported the route into the ConnectedApp, there are several choices (see screenshot).
                If you choose option 1, you can navigate the route as if you are using a track. The number of shaping points in MRA does not play a role here, nor does the chosen map.
                If you choose option 2, you are creating a route in the ConnectedApp based on the shaping points included in MRA. And then a maximum number of 50 applies. To ensure that the route matches your planning in MRA as much as possible, it is recommended to use the TomTom map there.
                  @MR-1600GTL
                  MR-1600GTL
                  MR-1600GTL
                  MR-1600GTL
                  @Jack-van-Tilburg Thxs. So TomTom Map is best in my case, with max 50 waypoints, which normally schould be enough. Thxs again.
                    @MR-1600GTL
                    MR-1600GTL
                    MR-1600GTL
                    MR-1600GTL
                    @Hans-van-de-Ven-MRA-Master Great addition. Thxs.
                    • Jörgen
                      The Rider 550 allows max. 250 waypoints in the ITN route file.
                      MR-1600GTL
                      MR-1600GTL
                      Brian Marchand 0
                      Brian Marchand 0
                        KaTo6668
                        KaTo6668
                      • How to plan correctly
                      • Offline Mode function
                        Thomas Neumeyer
                        Thomas Neumeyer
                        3.8k
                        Rob Veerman
                        Rob Veerman
                        Robineke
                        Robineke
                        231
