  4. Streckenführung über das Meer
14 Posts 5 Posters 634 Views 1 Watching
  • Wolfgang Hornundefined Offline
    Wolfgang Horn
    Hallo,
    bei der Routenplanung von A nach B werde ich teilweise über das offene Meer geführt. Das kann ja wohl nich sein.
    Bitte um Hilfe!
    Herko ter Horstundefined Wolfgang Hornundefined 2 Replies Last reply
    • Wolfgang Hornundefined Wolfgang Horn
      Hallo,
      Bitte um Hilfe!
      @Wolfgang-Horn From where to where? If there is a tunnel or ferry service, it will be used.
      Wolfgang Hornundefined 1 Reply Last reply
        Wolfgang Horn
        @Herko-ter-Horst
        From Bruchsal to Reggio Calabria.
          @Herko-ter-Horst
          Jack van Tilburg
          @Wolfgang-Horn said in Streckenführung über das Meer:
          It will help if you post a link to your route so that we can take a look.
          Don't forget to set the privacy of the route to 'Public'.
          And indicate the waypoint number where it goes wrong.
          • Herko ter Horstundefined Offline
            Yes, please share your route. If I just create a direct route from Bruchsal to Reggio Calabria, I get what I would expect, a route that looks like this:
              Hallo,
              Bitte um Hilfe!
              Wolfgang Horn
              @Wolfgang-Horn
              Hallo,
              hiere is my screenshot.
              -TomTom gold street map
              -No highway.
              Thanks!
              Jack van Tilburgundefined Herko ter Horstundefined Con Hennekensundefined 3 Replies Last reply
                @Wolfgang-Horn
                Hallo,
                -No highway.
                Thanks!
                Jack van Tilburg
                @Wolfgang-Horn
                We didn't ask for a screenshot?
                  @Wolfgang-Horn
                  Hallo,
                  -No highway.
                  Thanks!
                  @Wolfgang-Horn There is a ferry service from Salerno to Messina on Sicily (followed by a ferry from Messina to Reggio Calabria) which apparently TomTom thinks will take you there faster than using secondary roads over land. If you also tell MRA to avoid ferries, you'll get a fully overland route. Or just add more waypoints.
                    @Wolfgang-Horn
                    Hallo,
                    -No highway.
                    Thanks!
                    @Wolfgang-Horn, The trick is in the "No Highway". If I force the route over land, I need two extra waypoints, and the route-time increases by over 2,5 hours. So, it seems by boat is quicker than over land if you avoid highways in that area. According to the TomTom map anyways...
                    Streetpilot 2610 / Zumo 660 / Zumo 395 / CAT S52 + MRA app
                      Jack van Tilburg
                      @Con-Hennekens @Herko-ter-Horst
                      I think it would be a good idea if TS delves into creating a route? Why doesn't a route do what you want if you only put two waypoints on the map?
                      Ich denke, es wäre eine gute Idee, wenn TS sich mit der Erstellung einer Route befassen würde? Warum macht eine Route nicht das, was Sie wollen, wenn Sie nur zwei Wegpunkte auf der Karte platzieren?
                      Anleitung 'Eine neue Route erstellen'
                        Wolfgang Horn
                        @Jack-van-Tilbue93ac0ee-77ec-41db-b7ad-d1645f039de8-grafik.png rg [link text](link url)
                          Wolfgang Horn
                          https://www.myrouteapp.com/de/social/route/8543515?mode=share
                            Jack van Tilburg
                            @Wolfgang-Horn
                            Thank you very much! 🙂
                            You cannot create a route with only two waypoints if you want to avoid certain parts.
                            Do as mentioned above by @Con-Hennekens and add more waypoints.
                              @Wolfgang-Horn
                              Wolfgang Horn
                              @Jack-van-Tilburg thank you!!!
                              Jack van Tilburg
                              Wolfgang Horn
                              • MyRoute-App macht was sie will - aber nicht was sie soll!
                                Lex.Kloet.RXundefined
                                Lex.Kloet.RX
                                616
                              • Route als track hoe werkt dit nu?
                                CD130undefined
                                1.6k
                              • MRA - weird "detour" created
                              • Voice Navigation anncouncement too quiet
                                Peter Zehentreiterundefined
                                218
                              • Tracklog omzetten naar route geeft veel verschillen
                                Jan Weerheimundefined
                                Jan Weerheim
                              • SilverFox Controller C 1
                                12.1k
                              • Stuttering menu after 4.4.0 update ?
                                Daniele Boncompagniundefined
                                Daniele Boncompagni
                                656
                              • app blijft hangen in herberekenen
                                Bouke Entundefined
