  3. Route - Navigationsberechnung
12 Posts 5 Posters 3.8k Views 3 Watching
  • Kronland
    Kronland
    Kronland
    Guten Morgen allerseits,
    wie kann ich bei my Route die Art der Navigation einstellen.
    Kürzere Strecke
    Schnellere Route
    etc. etc.
    Danke für die Hilfe.
    lg aus der Steiermark
    Joachim
    • Jörgen
      Hallo,
      einfach nach Aufrufen der Route die entsprechende Einstellung hier wählen:
      Der Strich für die schnellste, der Rest für Kurvig.
      Kronland 1 Reply Last reply
      • Jörgen Jörgen
        Hallo,
        Kronland
        Kronland
        Kronland
        @Jörgen
        Habe mich wahrscheinlich falsch ausgedrückt. Geht um die Planung.
        Hier finde ich diese Einstellung nicht, somit verrechnet er doch etwas komisch.
        zur Info: Gold User
        lg
        Joachim
        • Kronland Kronland
          Kürzere Strecke
          Schnellere Route
          etc. etc.
          Joachim
          @Kronland That is only possible if you use the Here map or the TomTom map to plan your route, and additionally, only in the travel modes for car, camper, and truck. In the Toolkit menu, you will find the option 'Route optimization.' There, you can choose between the shortest or fastest route.
          It's likely that you have selected the motorcycle travel mode. Within that travel mode, this optimization is not available.
            Kronland
            Kronland
            Kronland
            @Rob-Verhoeff Thanks,
            i want to plan a Route for motorcycle.
            Do you know the difference between car an motorcycle route options?
            Joachim
            • TorqueRider
              @Kronland
              There are almost no differences.
              But if you use "Transport mode motorcycle", restrictions implemented by the road authority and reported to the relevant map supplier are taken into account during planning.
              And it also has some disadvantages. See the screenshot as an example.
              With motorcycle mode enabled you will be redirected to a restriction that applies on Saturdays and Sundays. But the road is open for motorcycles from Monday to Friday.
              • Kronland Kronland
                Joachim
                @Kronland
                Motorcycle is always the fastest option, Car you can choose between fastest and shortest via the toolkit
                  @Kronland
                  @Hans-van-de-Ven-MRA-Master I doubt that. In the example of @Jack-van-Tilburg above, when I navigate the route as "car," I can choose between the fastest and shortest options. Both take the same short direct connection between waypoint 1 and waypoint 2. If I choose "motorcycle", the route takes almost twice as long. That is not the shortest route then!
                    @Rob-Verhoeff
                    That is because that road is closed fot motorcycles in the weekend
                    Rob Verhoeff Jörgen 2 Replies Last reply
                      @Rob-Verhoeff
                      @Hans-van-de-Ven-MRA-Master Ha, you beat me 😉 This 'seasonal'-weekendclosing is not known to Here then...
                      I do use your closures for the Netherlands. I've to look into the foreign closures also!
                        @Rob-Verhoeff
                        That are forbidden for motorcycles, click!
                          @Rob-Verhoeff
                          @Hans-van-de-Ven-MRA-Master said in Route - Navigationsberechnung:
                          That is the reason I use this nice street only during a week. 😊
                          But back to the question from Joachim.
                          Zur Planung von schönen Touren, gehst du in das Routenlabor und machst deine Einstellungen für eine Scenic Tour.
                          Das geht für eine Rundtour oder eine A zu B Tour.
                          Kronland
                          Kronland
                          • Testroute segmenten
                          • Bollard trouble
                          • Hide warnings on the map
                          • Minimap
                            LE DIZES Freddy
                            LE DIZES Freddy
                            Erdna
                            Erdna
