  4. Waypoints and voice guidance
12 Posts 4 Posters 83 Views 1 Watching
  • David Bonnerundefined Offline
    David Bonner
    I have noticed that voice guidance seems to be affected by closeness to waypoints.
    This week, I travelled a preplanned routes (ie with waypoints) and I noticed that voice guidance was not given if there is a waypoint near to a turning, either before or after it. I expected this if a waypoint is placed BEFORE a turning, as I read in comments on the forum that announcing waypoints takes precedence over voice guidance (even if waypoint announcements are not selected), but I was surprised that this also occurred even if the waypoint is placed AFTER the turning. When there were no waypoints nearby voice guidance approaching junctions etc was given correctly.
    On the return journey I simply put in the destination ie an A tp B route with no waypoints. And voice guidance was consistent at each turning.
    So I am wondering if this explains why voice guidance appears to be inconsistent? Is it because waypoint announcements are masking them?
    • David Bonnerundefined David Bonner
      @David-Bonner yes, could very well be!
      If waypoints are present, they are announced by the HERE navigation. Eg: “You’ve reached your waypoint, it’s on the right”.
      Turn instructions are also completely taken care of by HERE. If turns and waypoints are close together, a choice needs to be made (by HERE). It makes sense that waypoint announcements are chosen as they are created by the user.
      However, if you’ve turned off waypoint audio notifications, the turn instruction isn’t magically fetched. Resulting in no audio at all 😞
      I’ll have a look at the configuration options and see if anything is possible but I think this is just a really thing to deal with (sadly).
      David Bonnerundefined Stefan Hummelinkundefined 2 Replies Last reply
        David Bonner
        @Corjan-Meijerink Would an answer to this problem for both visual and voice guidance at turnings be to not display waypoints in the top left information box?
          @David-Bonner unfortunately not!
          David Bonnerundefined 1 Reply Last reply
            David Bonner
            @Corjan-Meijerink Thought it might not be that simple 😞 but I am sure you will come up with an elegant solution.
            Enjoy the rest of your break
              @Corjan-Meijerink said in Waypoints and voice guidance:
              Can you then scientifically determine how far waypoints shall be placed from these road occurrences?
              Corjan Meijerinkundefined Con Hennekensundefined 2 Replies Last reply
                @StefanHummelink No clue 😉
                  @Corjan-Meijerink then we shall do it all empirically haha. Test route with successively placing the wp further from the junctions hehe
                    @StefanHummelink, That could well be dependent on the length of the voice guidance that remains unspoken, and therefore also dependent on your speed (just a hunch).
                      @Con-Hennekens Would be my guess as well. Hopefully Corjan can find some workarounds.
                      Waypoint announcement, or anything regarding waypoint(specifically waypoint, and not viapoint) should be lowest in hierarchy imho.
                      Turn instructions should definitely be of higher priority than anything waypoint related. In fact, I feel like the app should not do anything with the waypoints, except for using them to shape the route and show them.
                        If only I could get access to the SDK source code 😉
                          @StefanHummelink, Depends... Often you get directions 2 or 3 km in advance. I'd say they don't need te be high priority. Also a user generated message (what a waypoint really is) would be of higher priority than anything auto-generated. I think it would be a tricky discussion. But I understand what you mean.
                          I guess you would really like that! 😉
                          David Bonner
                          • Te veel problemen
                            Lex.Kloet.RXundefined
                            Lex.Kloet.RX
                            432
                            Richard Blaauwundefined
                            Richard Blaauw
                          • BDR Route GPX Support
                          • Raul from Argentina
                            Nick Carthewundefined
                          • Motorhotel in de eiffel?
                          • Zu viele Wegpunkte?
                            Frank Schefflerundefined
                            Frank Scheffler
