  4. Experiences South England
14 Posts 5 Posters 84 Views 1 Watching
  • Edwin_M
    Edwin_M
    Edwin_M
    Forgot to add as positive.
    Once I deviated from planned routes and had a very curvy route planned by MRA. That was a nice experience. It got me on a few nice small road , I would not have found otherwise.πŸ˜‹πŸ˜„
    • Edwin_M Edwin_M
      @Edwin_M, If you run the latest beta, there should be an choice to enter off-line mode when internet is needed bu not available. That, in combination with downloaded maps, enables continuation without internet.
      Edwin_M 2 Replies Last reply
        Edwin_M
        Edwin_M
        Edwin_M
        @Con-Hennekens no not really. That resulted in the stated issues
          Edwin_M
          Edwin_M
          Edwin_M
          @Con-Hennekens also when you are driving and suddenly end up in a no coverage area, i don't think that is a desired way it should work.
          • Edwin_M Edwin_M
            @Edwin_M, What is the problem with going into offline mode when you enter a no-coverage area? What do you think is the desired way it should work instead?
            Edwin_M 1 Reply Last reply
              Edwin_M
              Edwin_M
              Edwin_M
              @Con-Hennekens In your proposed way, you need to stop.go to settings change mode etc. (take of and put back on the gloves if needed)
              I'd like the app to manage this for me. Online - offline can change any minute. i dont want to think about that, and centrainly not end up in a fault situation. I downloaded the maps and the route , so everything is availabe to do it for me.
              MotoCon Lynchy67 2 Replies Last reply
              • Edwin_M Edwin_M
                @Edwin_M, No, if you are in a non-coverage area AND you need internet access due to a recalculation or something like that, the app asks you if you want to go into offline mode. A simple tap does it for you. But I think your wish will get answered to, because I understood that the MRA team is looking into automating that in a future version.
                richtea999 1 Reply Last reply
                • Edwin_M Edwin_M
                  Lynchy67
                  Lynchy67
                  Lynchy67
                  @Edwin_M said in Experiences South England:
                  Am I misunderstanding Offline Mode in the current Beta?
                  If I have the relevant maps downloaded in the app and the relevant route in the Downloads in the App and I set the setting to Offline Mode I was under the impression I could stay in Offline mode indefinitely?
                  Is that not the case then?
                  • Lynchy67 Lynchy67
                    @Lynchy67, of course. That's the general idea. You just have to put your app in off-line mode. Else it wil try to use the non-existent on-line calculation.
                    It would be great if this could be changed to some kind of "hybrid situation". Try route calculation online and if not possible and being in the downloads map (or better: cached offline!) just use the local data. The app already does that with the offline maps. If available offline, just use it. Offline mode set to on is just a need for when you absolutely don't want to use metered data, even if available.
                    • Edwin_M
                      Edwin_M
                      Edwin_M
                      Also see
                      link text
                        @Con-Hennekens said in Experiences South England:
                        ... the app asks you if you want to go into offline mode. A simple tap does it for you.
                        (I'm making an assumption that no internet + option not ticked = no active routing, right? I haven't tried the feature yet)
                        If so, when I'm riding I'm busy with both hands on the bars, so the less touches the better.
                        Therefore, I'd like the app to recognise that I've selected the option and to swap automatically (to and from offline mode), in order to give the best possible result without me having to make that decision for it.
                        • RetiredWingMan
                          I understand they are planning changes in this area. Even adding an option to allow automatic switching to offline and or online would help solve some of the issues.
                          • richtea999 richtea999
                            @richtea-0, Yes it has been mentioned in the forum that work will be done to smoothen the experience.
                            Edwin_M
                            Edwin_M
                            Lynchy67
                            Lynchy67
                              Erdna
                              Erdna
                            • Bollard trouble
                            • Map movement
                            • Street view Preview on expert map folder
