New Beta! (v3.2.13)
@Corjan-Meijerink Today I spent a few hours navigating with the app while charging the smartphone with a Quad Lock wireless charger on my motorcycle. At the end of the ride, the phone's battery was charged to 100% and the device did not feel hot. So
@Bart-DM yes same with my iPhone 12 last weekend , 5 hours ride and no discharge or heat
Hi everybody!
We've got a nice new update for you! This time, we paid a little more attention to Android
(no worries iOS users, we also got some CarPlay improvements).Position indicator
Some testers made some fun that if I had a few hours left, we should be able to add customisation options to the position indicator. Some want a different color, some want the circle to be visible and others are happy with how it is. Rejoice! More customisation options
CarPlay
The changes above als apply to CarPlay!
Furthermore, the issue where sometimes an incorrect (the previous) maneuver was shown, has been fixed!
Also, CarPlay now also uses the new (correct) roundabout icons.External storage (Android)
If you don't have enough capacity on your phone and need to use external storage, that's possible!
Android stability
The same issue iOS had last week (https://forum.myrouteapp.com/topic/3721/ios-3-2-12-issue) which resulted in an immediate update, also caused some (less obvious) issues on Android. This now also has been fixed.
But most importantly! The issue which resulted in random crashes over the past months when using the app / starting your navigation has been fixed!
This means that as this point, Android should have a good stability.Have a great weekend and we're looking forward to all your feedback as usual
Cheers,
Corjan & Joost@Corjan-Meijerink ik heb afgelopen weekend en gisteravond nog nog gereden, en het volgende viel mijn op dat de kaart niet van 2D naar 3D kantelt, als je bv bij een rotonde aan komt zoemt hij in en de kaart kantelt ben je die voorbij kantelt hij weer terug naar 2D en zoemt uit, dit heb ik na de laatste update hij blijft nu de hele route 3D staan. En de afslagen worden niet consequent in spraak door gegeven, ik krijg de indruk dat hij bij provinciale het wel wordt aangegeven en de klein sluipdoor kruipdoor wegen niet in spraak wordt aangegeven. Ik zou vanavond nog gaan rijden is er niet van gekomen ik had in de app de vormingspunten uit gezet en zins dien heb ik het idee dat geen spraak geeft bij elke afslag die ik tegen kom. en nee ik heb niet de audiowaarschuwingen uit gezet. Gisteren avond heb ik de MyRoute-app opnieuw geΓ―nstalleerd. morgen ga ik rijden met de vormingspunten aan kijken wat hij nu doet. P.S. ik gebruik Android op de Samsung tablet.
Hi everybody!
CarPlay
Android stability
Cheers,
Corjan & Joost@Corjan-Meijerink Undoubtly a stupid question: how can I get the update to v3.2.13?
I tried both the TestFlight App and the App Store App: no success. -
I tried both the TestFlight App and the App Store App: no success.@Dikke-Wim Apple is normally a few hours after android before itβs released
I tried both the TestFlight App and the App Store App: no success.@Dikke-Wim Via TestFlight, but the update isnβt available yetβ¦ it takes a few hours.
@Bart-DM Thanks! Good to know.
@Bart-DM Even after 12 hrs: Still no update available... Am I doing something wrong?
@Dikke-Wim no, update isnβt available yetβ¦ on iOS ο£Ώ
Could still not find the update, but checked and I see it has been installed automatically (Android).
Offline maps needed an update, but would not complete that update.
After clearing data an cache I was able to re-download the maps. -
@Dikke-Wim you will automatically be notified on TestFlight, give it some time
No need to panic. -
No need to panic.@Corjan-Meijerink I don't panic, but admit it does take a long time this time
Hi everybody!
CarPlay
Android stability
Cheers,
Corjan & Joost@Corjan-Meijerink Any clue when the new version will be available in the Netherlands?
@Dikke-Wim update is available.
@Bart-DM Yes, thank you Bart
Downloaded it immediately
@Bart-DM Apple took its time
@Corjan-Meijerink yes indeed
@Corjan-Meijerink Will there be an update this week? Matter of keeping tradition alive
@Bart-DM hahah, no there wonβt be an update
With your input, this post could be even better π
