  3. [App-Beta] Announcements
  4. New Beta! (v3.2.9)
New Beta! (v3.2.9)
40 Posts 13 Posters 702 Views 6 Watching
    @Vlad-Popovici-0 We hope the crash frequency is reduced in 3.2.9 but we are not sure about that. Looking forward to your feedback on this matter!
    Considering your 3 feedback points:
    1. Has been noted and will be addressed before release.
    2. Will be considered! See my elaboration below.
    3. This should be possible already. By tapping the ETA widget you cycle between end / upcoming shaping / upcoming via.
    You can use track navigation for routes by exporting it as GPX and importing that file as route-track. This route-track can then be navigated with the app as track navigation. Yes, this is very tedious and we will check the possibility to implement track navigation for routes too.
    Cheers! 🙂
    Vlad Popovici 0
    Vlad Popovici 0
    Vlad Popovici 0
    @Corjan-Meijerink I will check the ETA to via point, it seems I missed it.
    I did that, exported to route-track, but I missed too much the route only features (like different points colour, or icons, or via points), so I stopped using it like that. Would be AWESOME if you consider implementing track navigation for routes too.
    Best regards!
      Cheers! 🙂
      Vlad Popovici 0
      Vlad Popovici 0
      Vlad Popovici 0
      @Corjan-Meijerink Just checked, indeed one of the toggles shows the ETA to the via. AWESOME!
      So only 2 things to perfection 😁
      Also I love the new menu.
      One little thing: when I start the tracklog, in the normal app, a notification says "Recording". In Next, there is no notification. I know the orange trail is the best indication, but an instant notification that you toggled it would be welcomed.
      • Arno 0
        Arno 0
        Arno 0
        if you want to close the menu you have to move the slider down. However, if you want to close the information box shown after clicking on a waypoint, you can also click somewhere on the map above the information box. I like this very much and wondering whether this can also be implemented for closing the menu.
        • Jörgen
          With the latest version, I noticed, much less voice commands.
          Much less than before, however, a little too less for my feeling. Ok, I know that everyone feels differently, and it is difficult to find the right way.
          • Jörgen Jörgen
            @Jörgen funny, this hasn’t been changed at all 🙂
            MotoCon Jörgen 2 Replies Last reply
              @Corjan-Meijerink, 🤣 🤣 🤣
              • flamingm0e
                flamingm0e
                flamingm0e
                Still having a lot of random crashes. I can't pinpoint what causes them.
                Offline Maps:
                There is no indicator if you already have a map downloaded, or while it's downloading maps, there is no indicator of WHAT it's downloading or even IF it's downloading. I go to Offline Maps, select USA, and clicking on anything just shows a spinning circle...where is the progress? Where is the indicator whether you have downloaded anything or not?
                General app issue:
                Occasionally when I click on the hamburger menu from main page, select my "account avatar" at the top right, it prompts me to log in again. If I close out, and reopen, it will show I am already logged in.
                MotoCon Corjan Meijerink 2 Replies Last reply
                • flamingm0e flamingm0e
                  Offline Maps:
                  General app issue:
                  @Matt-Flaming, all maps that are downloaded show the "X" in the list, instead of the download arrow. But the overview of downloaded maps like Navigation has, is missing indeed.
                  flamingm0e 1 Reply Last reply
                    @Corjan-Meijerink I can't believe that?
                    I drove the same route with a former version and I get noticed by voise command about a roundabout 6-7km in advance and min. 4 times before.
                    And now only 2 times. Anyway much better. 👍
                    • Jörgen Jörgen
                      @Jörgen yet, it’s true hahah 😉
                        Offline Maps:
                        General app issue:
                        @Matt-Flaming we made some UI improvements in the upcoming update. For now, the "x" indicates it can be removed, which is only possible when it has been downloaded.
                        The spinning circle means it’s still starting the download or below 1% progress. It should start indicating it’s progress as in my original screenshots. If it seems stuck, try rebooting the app. If you are prompted with an available map update, do that first 🙂
                        The Android crashes is something we are working on!
                        Regarding the profile issue, I’ll check that.
                          flamingm0e
                          flamingm0e
                          flamingm0e
                          @Con-Hennekens said in New Beta! (v3.2.9):
                          Then nothing is downloading for me, as I don't have an X next to anything in my list of states in the USA.
                            @Matt-Flaming if you downloaded the entire USA, the state will probably be reflected in the top right corner (when viewing the USA). Feel free to share a screenshot! 🙂
                              flamingm0e
                              flamingm0e
                              flamingm0e
                              wrote on last edited by flamingm0e
                              #31
                              @Corjan-Meijerink said in New Beta! (v3.2.9):
                              After trying for a couple of days now, it looks like it MIGHT be downloading the USA. I have 2 devices trying to download now. I've been trying this since the release of this beta, and it never has done anything but spin the circle (3 different WiFi connections and 5G). I have NO indication of download speed, or how long it estimates to take. And without an ongoing notification in Android, it will just fail silently if I navigate away from the screen or try to use another app while it's downloading (I do have battery optimizations turned off).
                                @Matt-Flaming I’ll give it a go to! Let me know if it gets downloaded. It should resume in the background if the app isn’t killed.
                                  @Matt-Flaming, you download the US as a whole, the X is ONLY at the top and you cannot delete individual states. At least, that's how it looks now. So if you want a few individual states, you will need to download those seperately.
                                  Your comment on the absence of a download indicator, or progress status is of course very valid.
                                    flamingm0e
                                    flamingm0e
                                    flamingm0e
                                    My problem was that I tried downloading the entire USA, and it didn't finish downloading in the background. So every time I opened the offline maps page, the X was there with a spinning circle and no way to determine what was going on.
                                    The lack of detail on that page makes it pretty confusing.
                                    I think I have the USA downloaded now. I'll find out as soon as I get a chance to actually use the app rather than playing around with it at home and commutes back and forth to work.
                                      @Matt-Flaming agree, more details will be added.
                                      Please note that offline routing doesn’t work yet.
                                        flamingm0e
                                        flamingm0e
                                        flamingm0e
                                        @Corjan-Meijerink Thanks
                                        • Vlad Popovici 0
                                          Vlad Popovici 0
                                          Vlad Popovici 0
                                          I tested the v3.2.9 today again for the 3rd time. Everything was perfect. No more crashes for me, at least for now.
                                          About downloading offline maps, indeed there is no progress indication if you download a full region, example Europe or France. You just have the X, if you press it early you will notice some were downloaded, some weren't.
                                          If you download items individually, then you have a progress circle.
                                          Vlad Popovici 0 1 Reply Last reply
                                          Arno 0
                                          Arno 0
                                          Vlad Popovici 0
                                          Vlad Popovici 0
                                          Steve Lynch
                                          Steve Lynch
                                          flamingm0e
                                          flamingm0e
                                          Jure Sirena 0
                                          Jure Sirena 0
                                          Koen VH
                                          Koen VH
                                          • Map lock
                                            tfdahazellgmail.com
                                            tfdahazellgmail.com
                                            98
                                          • Beta abonnement
                                            BMW1300GSA
                                            BMW1300GSA
                                            2.3k
                                            Gerard van der Veer
                                            Gerard van der Veer
                                            520
                                          • Uitnodiging
                                            Hanza 0
                                            Hanza 0
                                          • Suggestion: Make the layer icon permanently visible
                                            Hans Kremers
                                            Hans Kremers
                                          • SilverFox Controller C2
                                            Hans Lamers
                                            Hans Lamers
