  4. Problems with the Route Generator
5 Posts 2 Posters 97 Views
  • UltraStar
    UltraStar
    UltraStar
    iPhone 11P, iOS 16.3; Next 3.2.8 - 151.
    I have used the Generator to create short route. The firs screen shows grayed out map with the information window at the top to enter the start point of the roundtour.
    1. Could you make this text more highly visible, maybe an some icon would help.
      I know you cannot go any further without pressing this button, but - at first time you see the screen - you are looking at it, and "what now?"
    After I entered the start point, I had trouble finding the next step; the text on the bottom of the screen (Show roundtour settings) is very small and not very intuitive.
    2. Larger, more highly visible button to go to the next step would help here.
    Once the roundtour is generated, the screen displays several optional routes with the distance and elevation statistics at the bottom.
    3. The elevation feet on the left side of the screen are cut off.
    4. Again here, larger, better visible button to go to the next step would help here. I am repeating myself. 🙂
    5. First time doing it, I was lost. Where do I go from here. OK, I can zoom in and select a route, and then what? There is no button to start the route, or to go somewhere to start it.
    Finally I figured that out, and went to routes, and selected saved roundtour to start the navigation.
    Once I pressed the button to start the navigation, I was presented with the error screen; I had some calculations errors (darn math again!)
    After pressing Yes on the error message screen, that is what I have seen.
    After closer investigation, I have found out that the generator uses OSM to create a roundtour, and HERE maps are little different. I have compared the maps with OSM, Michelin, HERE and Google. Google and HERE were right on the button; Michelin so so, and OSM not so. OSM uses some dirt roads, stabs that were never finished (or abandoned over time,) etc. Here are some samples.
    And five more like that. Hmmm, I think I have seen number 6 on the screen with the errors (darn math again!) Yes, I did, but number 5 is missing?!
    If it is possible, can you use the HERE maps to generate the roundtours? This way the same maps would be used for navigation.
    UltraStar 1 Reply Last reply
    • UltraStar UltraStar
      UltraStar
      UltraStar
      UltraStar
      @UltraStar One more thing, when you Play the route, it uses the OSM so there is no problem navigating. 🙂
        Thanks for sharing! The route generator is within the website and therefore the experience is suboptimal. This will be ported to natively within the app in the future! 🙂 To be even more precise, we are now working on a native roundtour generator!
        Unfortunately we will continue using OSM to generate the route as here does not support curviness settings, therefore those issues will continue. As you noticed, we do inform you about possible misplacements of coordinates.
          UltraStar
          UltraStar
          UltraStar
          @Corjan-Meijerink Thanks for explanation. I have forgotten that HERE does not support curviness. Little more work when generating the roundtour. Not a biggie.
            @UltraStar No worries 🙂
            UltraStar
            UltraStar
            • Kaart niet zichtbaar
              212
              BĂŠ Jeuring
              BĂŠ Jeuring
              22
              41
              364
            • Xpert overlay not clear
              Corrado Miniati 0
              Corrado Miniati 0
            • Google maps
              Ed Bos 0
              Ed Bos 0
              208
            • Trains like Ferries?
              Corrado Miniati 0
              Corrado Miniati 0
              288
